- Aug 18, 2007
Lets go full Saginaw!
so you finally figured out why it wouldn't work for you?spinning the pump backwards?
What does your bracket look like?
Which pump did you go with? How well did the lines work or did you have to redo the pressure line?
The pump was off an Econoline 302. Same with the lines.
Hey hey, there you go!Might get a bunch lazer cut.
