Why do you have the res clocked over so far? Clearance issues?
It's no where near done yet. I've got the compressor to mount up still.![]()
What pulley's are you guys using? My steering pump is new and loud. I'm sick of these remanned pumps.
The tbird pump was very expensive remanned. Very near the cost of an AGR pump.
93.99+45.00core. 138.99 is pretty expensive for a power steering pump.
Not with the place any more but may have access still. Moved on to bigger and better things. I need to get my york mounted at the same time as the newer pump as I only want to do this once.
AGR pump http://cgi.ebay.com/ebaymotors/AGR-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I was told that the SOHC pump is a better pump. It is even a remote res pump. Anyone confirm this?
what year model?The pump was off an Econoline 302. Same with the lines.
shaft diameter?The stock RBV pulley will not work with the Saginaw pump.
