OilPatch197
- Sep 23, 2007
- Age
- 96
Yeah, that is the question.
I have always considered it a Engineering flaw to build something that is difficult to work on. Keep things as simple as possible.
Automobiles should not be difficult to work on, you should NOT need a distributor hold down bolt wrench, nor should you need a code reader, tamper resistant torx bolts? Twelve sided bolt heads in a odd size(when a six sided bolt would work), complicated electrical connectors(in twenty years will snap off the tabs because of brittle plastic), so on and so forth.
Then there is the dual measurement, standard and metric, so you got to buy even more tools. Then there is finer torque specs on bolts, no longer is a Ft-lb. wrench any good, you need a inch pound one too!
Don't even think about reusing the head bolts!
..now us backyard mechanics, I would just get out the vise grips, snap her on and turn that fastner, but there is NO ROOM! Many times I needed a 11mm deep six sided socket with thin walls to get off a ignition control module! I couldn't use a short socket with ext. because the walls were too thick, not enough clearance around the bolt!
Now I'm not saying there should not be specialized tools, I think there should be to help the repairman to do the job quickly, but often those that work on their vehicles have to modify a tool, or drive to town to buy one, and this hurts when you need to get the vehicle up and running.
