- Aug 6, 2007
- Pittsburgh PA
First you need to decide how low you want to go. You can do dropped I-Beams for 3'' of solid drop. If you go with the 2'' coils, you probably won't net a true 2'' since the stock coils have sagged a bit form age. Combine the two and you have a 5'' drop. If you do use coils to lower your truck, get aftermarket eccentrics so a shop can put you back in alignment.
The rear is endless. For dropping cheap and about 2'' flip your shackles. The only cost is time and some bolts. You can do a flip kit for cheap as well and net 4-5''(you'll want to notch the frame too). There is also the option of ordering drop leaves to get the drop you want. The you can start mixing and matching methods.
If you've mess with cars, alot of the same rules apply. Just take what you know and try it. Got a question, ask it. Welsome to TRS too.
James
James
