- Aug 20, 2009
- Connecticut
- 2.9L
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- 235/75/r15
Alright so a few things I’m dealing with. I bought this truck not running supposedly the shop I bought it from had it running, they said it needed a fuel pump and injectors. It was sitting for like 20 years. Just put a new pump and injectors in it. The truck won’t start off the ignition key, it’s a manual transmission I’m thinking the safety switch on the clutch pedal is causing that? No big deal I jumped the solenoid with key on. The pump runs continuously even with key off, I tried swapping relays with the a/c relay and it still does the same thing. I noticed the fuel pump relay was getting hot so I’m assuming the contacts are stuck closed?
Only other thing I can think of is maybe it needs a new ecm?
Kinda not sure of where to start troubleshooting this?
The new pump is a Delphi unit.
Any help is greatly appreciated!
