4.0L SOHC Weird coolant leak
Turtle12400
Forum Member
Florida
FL - USA
Drive
2007 4.0 SOHC with 130k ish
I've had a persistent weird coolant leak for a little now. When the radiator is filled and the overflow tank filled to the proper level, the truck pisses coolant out of the front cover area around the crank pulley until the overflow tank is dry and there is about a half inch of air in the radiator. After that, ZERO coolant leaks out and the truck runs and drives absolutely as normal. ZERO overheating issues at all.
I've had the thermostat housing explode already and I replaced it with a cast housing, so that isn't the issue. Hoses are nice and tight with worm gear hose clamps.
I have coolant dye in the system from that job, so that's making my life easier for sure. From my inspection so far, it appears that the coolant is leaking onto the crankshaft position sensor and dripping down from there. There is no play in the fan clutch pulley.
My thought is that the water pump is leaking, but before I really dig into it I figured I'd get some input from more experienced folks. Any notorious coolant leaks I should be aware of aside from the thermostat housing issue?
Thanks ya'll!
Alright little update. As you can see, coolant appears to be gathering on the bottomside of the water pump housing. It seems like it might be leaking out of behind the fan clutch pulley? The coolant residue is on the bottom of the actual water pump housing and not coming out of the mating surface.
Weird coolant leak
Would this match with the leak stopping at a certain point and not continuing to leak past that point? And does this mean I need a new water pump.
Trippy.
It's not uncommon for a water pump to leak
And it sure looks like yours is leaking.
Sounds l8ke waterpump leak. Probably coming out of the weep hole which means shaft seal is leaking.
Alrighty. Thanks ya'll!
New water pump is getting ordered.
And it probably stops leaking after the level drops because it can't build pressure anymore because of the air in the system. Kinda like running with the cap off the radiator.
Oooooohhhhh. This was honestly my biggest question, and this answer makes total sense.
I hope I haven't done any damage driving it like that.
If it truly didn't overheat, you're fine. I've known many vehicles to be driven that way for years.
Yeah it literally never had any overheating issues. The gauge has always sat exactly where it should, and I've been very attentive to the temp since I noticed this issue.
Okay ya'll. It's been a bit since I've replaced the water pump and unfortunately the issue has not been resolved. I honestly haven't got a dang clue why but it's doing the same thing, dumping the top of the radiator out and stopping after a bit less than an inch below the top of the rad.
The system still pressurizes and temps are still perfectly fine, just the same symptoms. Any ideas?
Since I put new coolant in I'll get new coolant dye in there and try to pinpoint the leak better. Thanks!
Any luck tracking this down? I just got an '06 that I was assuming was the water pump also, and was not looking forward to tackling it.
Same here except I've replaced my water pump. Still losing coolant but can't find where it's going and I'm hoping it's not a head gasket issue.
Yeah no luck. I've gotten fucked lately with time so I haven't touched it.
I can't imagine mine is a head gasket issue as I'm losing coolant externally, right?
Upcoming TRS Events
Featured Ranger Based Vehicle
