5.0 Manual swap- 2002- Hurdles
What's the % chance of failure if I just buy a '97 ecu and hook it to a '01 engine and call it a day?
High?
The 97 Explorer uses a “low pressure” return style fuel system. Rangers from 98-11 use a “high pressure” returnless style system. So the fuel system out of the box is incompatible. The fuel rail and injectors are different as is the computer controls for the fuel system. You either have to adapt the fuel system (although I’ve been told that you can’t adapt it nobody has been able to tell me exactly why it can’t be done), or you need to go to an aftermarket computer system where you can make the appropriate adjustments
Yeah, that... they changed all sorts of random stuff when they swapped to returnless like injectors as LBF mentioned... I mean if you got a return style 5L you could use the stock fuel supply and just add a return to the tank somewhere... there's options but some things are easier than others.
fit on the back of a ford transmission?
i want to keep costs low right now. i get that an ls is a better motor and what have you but the price of getting everything adapted and finding a good transmission is higher than it would cost to get a 5.0, rebuild it, and drop it straight in.
besides if i decide I don't like a 5.0 I can always take it out later and swap an ls in.
there are no hard and fast things with swaps that do not involve location and what is readily available....some areas of the country might make a toyota v8 swap logical. so that is a thing.
if you are a ford purist or already have a bad ass ford powertrain, by all means use the ford... this is the most likely way to keep it par with a LS swap. problem with a LS swap is people buy shit they dont need. that is that persons problem.
goal...objective...clarity of execution.
the LS is NOT a better engine than the windsor in my eyes....its awesome....it is simplified....easy to work with...but gives up some oiling that will not let it rise above the windsor.....par for sure....but that is one idiots opinion..
the cleveland otoh....i had to redo my list. on the last three projects i assisted on....well.
for a ranger platform...
to say its cheaper and easier to do a 302 swap is just simply not true for the only reason to swap a v8....for a competent mechanic...
glorious sound and POWER.
doing a poor boy junkyard swap which is my deal....
to me...starting with 100 more hp for the same price is a no brainer.
if you wish to retain efi...the tuning and ecu are far superior and way more cost effective and last longer than eec4 or 5.
though these days i say run speeduino right out of the gate. no matter what engine if it has pushrods.
for your case...
your chassis being cheaper than an LS is almost true, as the engine itself has a bolt in solution. interfacing with the ac and cruise ect can be easier...potentially bolt in...i say potentially because it depends what you are starting with... for the uninitiated anyway...
problem is....for the least competent mechanic....installing the powertrain is the easy and fast part. you dont need adapters....cross u joints maybe...that could be a thing...if it cost you more than 100 bux to install an LS powertrain...not interactive mind you...just bolt in... then any engine will be an issue....generally the driveshafts could cost more...as you prefer a manual...and those transmissions are on the high side regardless of brand. even the r2 is expensive where i am...
the average 5.3 and trans assembly is par in cost and procurement in my neck of the woods.
when you prefer a 4x4 with manual it is for sure getting higher dollar no matter the brand...this should be read under a 1000 dollar limit for engine trans and t case is not a 3 minute phone call anymore with one stop. plan on 1200 and 3 stops....
u pull yards are dying off and older powertrains are thinning in my area.
on a budget...
with the ranger and a LS 4x4 i would run a 4.3 s10 trans and t case....these run 350-550 locally and a 5.3 350-750 locally. same as a 302 and r2 trans.
problem running the s10 stuff is the 5 bolt thing like the ranger....just depends on goals and dollars willing to waste.
going up in t case
the fullsize 241 or jeep/dodge transfer cases fit better...and costs tend to be par.....the jeep dodge case. these also can be made to work with the ford trans...
and that is the thing. i use a ford 208 transfer case with a 4l80 and a 6.x diesel in my personal ranger. all with factory parts and one 70 dollar ring adapter....
that is a big block.....giant fat bastard super strong transmission and wide ass t case.
for some reason it fits.
the allure of the bolt in swap of a 302 over some other thing is pretty strong.
but ignorant....not stupid...ignorant. these are not always interchangeable. and ignorant is not intended as an insult....it is why you are asking questions.
there are several companies with clocking solutions .... there are several companies that will supply different input shafts for various t cases to make what you want to do work....often cost effectively...
so. goals and objectives.
said another way....
take the average junkyard in detroit....
two rangers two guys....say me and you.
you will do the ford explorer based ....me the ubiquitous 5.3.
i will do it faster.....cheaper and with ALOT more power.
if i can do that....anyone can.
will it be perfect.....no
will it be beautiful? fawk no
will i be having a blast.....yes.
At least around me... the pushrod 5.0 is becoming the new flathead.
that reads non existant to me.....
so if you are sitting on a pile of flatheads....
we need to flathead a massie with twin turbos....
Basically
Hard to find and if you find one the guy that dragged it out of a fencerow thinks he has a goldmine.
High?
That was a stupid question. I'm not sure why I didn't just think of finding a manual ecu for an 01 explorer, presuming they exist.
They are very uncommon, I wouldn't expect to find one very easily.
call around. the ads/dealers on ebay may be able to load you a tune and no pats...
i know there were a few but do not remember the name. one was doing the 4.6 as well
the one i did this week was in toledo...core supply iirc for a 300-6
on a budget...
My problems with the LS Swap:
Getting an AR5, an LS adapter, a new slave cylinder, 4l60 bellhousing, etc. Plus an LS flywheel- expensive. At least $800 for that adapter gear alone.
LS manual computer? Everyone uses a terminator. $1500 right there.
Not to mention the steering has to be modified, you need motor mounts, and very likely drive shaft work.
Compared to a 302:
Cheap
Ready-made computers for year of vehicle
No adapters needed for a manual
Minimal, if any, driveshaft work
Mounts right to existing points
Did I mention cheap? I can probably snag a motor, transmission, and transfer case for around $1200. ECU would have to be brand new, and the wiring harness might cause some issues.
If I wanted an automatic, the LS would be a no-brainer. But I don't. So I'm sticking with ford.
419 244 5555. call and ask....ya never know
Compared to a 302:
Cheap
the only advantage is if you find the correct donor...you will have a plug and play solution. this only works with your specific chassis. so that is a huge plus.
even with that...
everything you said......
no.
it dont math.
5.3--same price plus 100 hp.
if you are using an m5odr2 trans...its not any better than the 4.3 s10. same price.
so that is a zero.... there is just no reason to use x over y because its cheaper....it is not.
you can easily adapt the clutch line....40 to 60 bux fittings and hose
unlike what comes on the r2....the s10 transfer case unit fits. the older one will allow 1310 joint no problem
but doing the flange cv thing has options....regardless your fawked if you want a low range t case ...gonna be work. if you are careful its cheap....
hooking to the driveshafts has many scenarios....
with the sla truck if you retain the 4r70 and the 4404 you can use stock shafts in certain applications...there is a way to retain stock shafts with the 4404 and r2 unit....but no low range....if you want awd...it is the way.
its not always simply a bolt on the drive shafts with a 4406/7 and a m50dr2 but it is possible. regardless it does not one to one replace the 4404. just swap in and go. you have to do the same work the s10 unit demands.
so..
bolt in solution is 4r70 automatic with no adapter work and you need an awd 4404 setup.....with a stick and 4x4 t case things change......no win.
they already listed the fueling scenarios...this is delible though.
hp tuners.....
you need a tuner no matter what...some sort of way to get past the nutless stock 302 setup....
.even with a carb a good wideband is key. you will want to invest some money....
good luck getting 400 hp out of an eec cheaper than a 5.3.
i listed this.
s10 4.3 setup for manual trans and t case.
5.3.
this is par in cost with plus 100 hp.
you are not rebuilding a 302 to ls power cheaper. that is math.
tune repository.... there is way more shit there for free for the ls....growing is much easier.
fortunately for you the explorer engine in your chassis itself is a bolt in solution....with the ttb chassis the LS really makes sense.
if you own a drill and a cutoff wheel and buy or find some scrap 4x4 or 5x4 box stock you can bolt an LS in too...
unlike the ford, you can actually rework LS exhaust manifolds with a 110 welder and get great return. i have run 500 hp through a set.
i have done so many swaps its a nothing to me. my issue is trying to talk yourself into something that is not true.
getting an intact gm fead and wiring system is much easier in my area...the eec4 and eec5 ecms are scavenged 3 times a week to core.
you can spend a million dollars swapping a LS engine....or 300....
i have built dozens of rangers. depending on chassis its often harder to put a ford in it.... well....not that that is hard...just in relatives.
really the rangers are easy to do anything to...it is why i love them.
[td]
Engine Assembly
Chevy Truck Silverado 1500
[/td][td]5.0 Manual swap- 2002- HurdlesRAN GOOD
Estimated CO2e Savings: 1194kg
[/td]
[td]
[/td]
[td]
X
[/td][td]
200049
[/td][td]
$375
[/td]
[td]S and H Auto Parts USA-MI(New-Boston) Request_Quote 1-734-782-[/td]
[td]96
Engine Assembly
Ford Explorer
[/td][td]5.0L,AWD,AT,ED BAUER
[/td]
[td]
[/td]
[td]
X
[/td][td]
AA0115
[/td][td]
$450
[/td]
[td]L and L Auto Parts, Inc. - PRP Freight, CDC USA-NC(Grover) Request_Quote 704-487-7401 / 704-937-9333 / 800-289-5474 Request_Insurance_Quote[/td]
[td]995
Transmission Assembly
Chevy Truck 1500
[/td][td]5.0 Manual swap- 2002- HurdlesMT, 4x4, integral bell housing,5.0L,F-5SPD,4X4
Estimated CO2e Savings: 1047kg
[/td]
[td]
289,000
[/td]
[td]
C
[/td][td]
21338
[/td][td]
$750
[/td]
[td]Hartlaub's Used Auto Parts USA-PA(Gettysburg) Request_Quote 717-637-1990 Request_Insurance_Quote[/td]
[td]1997
Ford Truck F150
[/td][td]5.0 Manual swap- 2002- HurdlesMT, (5 speed, Mazda, Toyo Kogyo manufactured), 4x4, 6 cylinder,4.2L,MANUAL TRANS,4X4, 30 DAY WARRANTY, SHELF 8 RED BARN
[/td]
[td]
135,000
[/td]
[td]
A
[/td][td]
02846
[/td][td]
$600
[/td]
[td]R&A Auto Salvage USA-OH(Findlay) Request_Quote 419-420-0653 Request_Insurance_Quote
Live Chat
[/td]
[td]996
Chevy S 10
[/td][td]5.0 Manual swap- 2002- Hurdles5SP,4.3L
[/td]
[td]
200,896
[/td]
[td]
C
[/td][td]
4A0405
[/td][td]
$450
[/td]
[td]Allstar Auto Salvage LLC USA-MI(Owosso) Request_Quote 989-472-3500 Request_Insurance_Quote[/td]
Also, the 99-01 Explorer had the same fuel system as your Ranger, but a different PATS system. So that has to be addressed.
When we did Dad’s 5.0 swap, his driveshafts worked. When I did my swap, I had to use the Explorer front shaft and I had to cut something like 2” out of my rear shaft. I’m not sure I fully understand what was different with mine other than I swapped in the Explorer axles and lowered the truck. I did the swap on the axles because I wanted the disk brake rear and the gears that were in my donor, my Ranger had the 8.8” in the rear stock, so it shouldn’t have really been any different :dntknw:
Dad’s Ranger got a 5.0 for the convenience of it all. He bought a 2000 Ranger in perfect condition other than the crank snapped off at the front of the block. He had asked about swapping a 4.0 in and I said no problem, find a motor. Well, we had problems getting our hands on a good motor and dad was finding a lot of 5.0 motors for sale and asked me if that could work. So I did my homework on TRS, told him what we needed, and we put it together. It was what we needed to do to make it work. That it made V-8 noises was a bonus.
My 5.0 swap happened because it was a 17 year old’s dream truck. The exact final product is a refinement of the original concept and the 331 stroker part hasn’t happened yet, but basically it’s there. Are there more modern options that make more power? Absolutely. But this was a gravel driveway build of a kid’s dream. Like my Choptop, a fun toy. Will I possibly build something with a more modern engine? Most likely after I get a garage.
Swaps have a ton of variables. There’s some really cool options out there anymore, but the farther you venture off the beaten path, the more you need fab skills and dedication. A garage to work in helps a lot, even better is having a lift in the garage. None of that is necessary, of course, but it helps.
