Motorcraft Spark Plugs
Bob Ayers
Durham, NC
There always seems to be a lot of "what's the best plug to use" threads. Overall, the top plug seems to be the OEM Motorcraft (which I believe).
I found something that might explain why the Motorcraft plugs run
better.
Check this out, one thing to notice. I picked a 2006 Ranger for this, but if you look at the recommended plug from Bosch, NGK, or Denso, they recommend the SAME plug for the 2.3L, 3.0L, and 4.0L. Only Motorcraft recommends a
different P/N for the 2.3L, 3.0L, and 4.0L:
SP439 for 2.3L, SP432 for 3.0L, and SP412 for 4.0L
So, the heat range is optimized for each engine with Motorcraft, NOT the
aftermarket plugs!
I'm of the opinion "close enough" only counts in horseshoes and hand grenades, NOT spark plugs!!
i have done many misfire repairs that someone has just used some crappy plug, normally bosch platnum, and the plugs need to be redone at their expense. can we say negative cost savings.....
The misfire story is pretty consistant with Bosch plugs. After buying my 1999 Ranger (used with 36K miles) it developed a misfire, only to find the previous owner had installed Bosch plugs. I replaced them with Motorcrafts, and haven't has a misfire yet!
wish I would've come on here and asked about plugs before I put the Bosh plugs in my rangers... doh! my 3.0 does have a slight miss, maybe i'll try going with the motorcraft... as for the 2.3 that was too much of a pain in the ass to change them again so soon. haha.
I put a set of Bosch platinum +4's in my park avenue and was amazed at how much they sucked! Had a miss right off the bat! I had to test these bad boys out on the car that was both my daily driver and had the hardest to plugs to get to! Sound familiar?
Anyways, Hank Hill uses autolite plugs in his ranger so end of discussion there.
so whats the number on the motor craft plug for a 90 4.0 also what about the ngk v power plugs
Motorcraft AWSF42P (double platinum) or Motorcraft SP486 (fine wire platinum). Plug gap is 0.054"
