Uncle Gump
Boomers gotta Boom
TRS 25th Anniversary
- Sep 17, 2018
- Ottawa
- State - Country
- IL - USA
- Other
- 1986 Bronco II
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0L
- Total Lift
- 1 inch
- Tire Size
- 265/75/16
- My credo
- Lead or follow... or just get out of my way
I don't typically question your electrical chops... but... ECM provides ground to the fuel pump relay in RUN... not START.Regarding the perceived ground problem;
Since the PCM supplies ground to the fuel pump relay coil, if you measure across the coil contacts where the relay plugs in, it WILL look like there is no ground, unless you turn the key to the start position to make the PCM supply a ground. And, even then, it will only be for a few seconds.
The best you can do is measure from the coil contacts to ground and make sure the PCM power relay is sending voltage to the coil.
I agree with the perceived "ground" issue. It's unlikely because there is no solid ground source at the fuel pump relay... only a switched ground from the ECM to energize the fuel pump relay under predetermined states. If it was a ground issue... you would have bigger problems.
I'm still confused on how the relay was tested to see this low voltage condition the OP described.
