Coming back after years…
Heather’s94
5+ Year Member
Brighton TN
Was on here about 5-6 years ago. Same name, same truck, but Heather moved on to greener pastures.
For those who don’t remember, our foster daughter Heather insisted that she “had to have” my late brother in law’s 94 rcsb 2.3/5spd rwd, Barney, the cranberry metallic with 1992 Sport wheels. She turned 17 and eloped to another state, after I spent a small fortune getting the rear suspension, lights and ignition system upgraded.
Fast forward to $5/gal 90 octane ethanol free, a lifted 1t 4wd dually with 60 gallon tanks, and a 10mpg thirst… Barney is getting reborn, again.
Glad you're back. Wish it was under better circumstances though.
We hear from her occasionally. She’s 22 now, healthy and has a daughter of her own.
It’s beyond time to fix up the truck. Prepping for a narrower rear axle and fiberglass monoleafs. Both out of a totalled 92 lwb I insisted we keep as a parts roach. 2” narrower, still 3.45 geared, 92 Outlaw 2 factory clones, 75k mile Generals in 225/70r14. Cut down the stock 60/40 into a 40-20-40, with the 20 being a built in cooler. Parts truck bed is getting installed on an old boat trailer as a motorcycle trailer, since Barney has a nearly colormatched “pet” 1999 Kawasaki 1500 Drifter. The 92 doors, hood and front fender are going to a friend restomodding a Bronco 2 for his newborn son. 92 transmission is going into a 1949 Dodge truck with a hotrod flathead 6. 92 frame needs to be pulled straight, picking up a junker 48/49 Plymouth sedan to build a “flower car” (Ranchero) out of.
Waste not, want not.
Cut the body off a 70's cobra and mount the cab and a faux bed. Then you can do rally cross and pretend you have an expensive car still =D.
Now. A more unrealistic idea. Short 3" lift, nice 31" tires, upgrade to 16" rims, and do mid-travel 2 stage suspension. Then swap to a mid-gearbox (aftermarket overdrive) and mount it backwards. Supercharge the engine and see what kind of lift you can get off the front when you floor it.
Or you can be normal and get it running, road worthy, and gas efficient. I like the third idea.
I have 4 fullsized trucks for actual “truck stuff”…
Same here =D, then I have a ranger and a ranger and a workman and a gator for the small stuff.
Let’s see… 1949 Dodge 1/2t 2wd, 1968 Dodge M400 based rv, 1969 Dodge 1/2t 2wd lwb being converted to 3/4t 4wd, 1985 C10 swb lowrider project, 1985 C60 lineman truck, 1992 K1500 ecsb Z71 roach, 1992 Ranger 2wd lwb roach, 1994 Ranger 2wd swb, 1997 Ranger 2wd swb, 1999 K3500 c&c dually, 2007 Ranger 2wd swb…
Suzuki LS650 Savage x2, Suzuki VS800 Intruder, Kawasaki VN800A, Kawasaki VN800E (Drifter) x3, Kawasaki VN1500R (Drifter), Kawasaki VN1500J (Drifter)…
1972 Super Beetle, 1995 (first year) Outback battlewagon project, 2006 “Potty Shack” Vibe (rebadged “Toiletta” Matrix)…
Plus a 30 acre yard doing its best to return to subtropical jungle. Yeah, too many irons in the fire, literally, own a coal fired blacksmith gig on the side.
