Lil set of channel locks for my man purse 👜
10$ at home shitpo, they've already come in handy.
Milwaukee wanted 35$ for theirs 🙄 get real.
I keep a a pair of those in my pocket at work and in the toolbox at home. Too useful not to have around. With them, a knife, a 6" wide-jaw wrench, and an 11in1 screwdriver I can fix almost anything that doesn't need wiring work.
I'm such a big believer in the man purse at this point lol. Id very much like to find a small multi bit screwdriver to toss in it next as well as a little pair of dikes.
If you’re hanging around with a pair of Dykes, you probably wouldn’t need your own tools at all…
HERCULES Impact-Rated Hex Shank Titanium Drill Bit Set,
Most of my drill bits are dull and worn plus I like having the ability to just pop them into my DeWalt driver as opposed to cranking them down into a standard drill.
Please tell me you're putting stacks on a 3.0...
HE ordered a complete exhaust system cut into 6" pieces with slip couplings because a 10ft piece of pipe was too expensive to ship.
CP9190 is here. It does read live data. Nothing really abnormal IMO. All other test require it to be powered by the vehicle. I didn't get that cable or the disc with software. I did find the software on Actron's website via the Wayback Machine. Data recording is limited to 30 seconds and updates every 2 seconds. So it's literally just 15 snapshots. The owner's manual actually has specs for the power adapter. 5.5mm x 2.5mm barrel jack. Seems like the length should be in there somewhere. The manual even recommends battery clamps for vehicles that cut power to the lighter socket when the key is off.
