- Jun 6, 2026
- Clinton
- State - Country
- MS - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 3.0L
Hey everyone, long-time lurker, first post here. I recently picked up a manual '93 2WD Splash with the 3.0 and 3.45 axle. I was a little bummed to find out it's only rated to tow 1,800 lbs. I searched around but most of the axle discussions seem to be off-road focused. Apologies if I missed something relevant.
My goal is to tow at least 2,000 lbs, and I'm weighing two options. I'm curious which route you'd take.
1. Tow 2,000 lbs as-is.
It's only marginally over the rating, and the bumper hitch is rated for 2,000 lbs with a 200 lb tongue weight. Mississippi is pancake flat, so grade isn't really a factor. The biggest concern seems to be braking, but since the automatic 3.0 with the 3.45 is rated for 3700lbs, I figure the brakes aren't the weak link.
2. Swap in a 3.73 axle and add a receiver hitch.
A 3.73 bumps the tow rating to 2,800 lbs. My local yard has several Rangers and sells axles with drums for $150. I'm assuming a 3.73 shouldn't be hard to find and bolts right up. I know I'd need to address the speedometer/odometer with the new ratio. Are the clusters adjustable for this, or would I need to pull one from the donor truck to get accurate readings?
I appreciate your time and input!
