3.45 to 3.73 Axle Swap for Towing — Worth It on a '93 Splash?
Clinton
MS - USA
Vehicle
Drive
Hey everyone, long-time lurker, first post here. I recently picked up a manual '93 2WD Splash with the 3.0 and 3.45 axle. I was a little bummed to find out it's only rated to tow 1,800 lbs. I searched around but most of the axle discussions seem to be off-road focused. Apologies if I missed something relevant.
My goal is to tow at least 2,000 lbs, and I'm weighing two options. I'm curious which route you'd take.
1. Tow 2,000 lbs as-is.
It's only marginally over the rating, and the bumper hitch is rated for 2,000 lbs with a 200 lb tongue weight. Mississippi is pancake flat, so grade isn't really a factor. The biggest concern seems to be braking, but since the automatic 3.0 with the 3.45 is rated for 3700lbs, I figure the brakes aren't the weak link.
2. Swap in a 3.73 axle and add a receiver hitch.
A 3.73 bumps the tow rating to 2,800 lbs. My local yard has several Rangers and sells axles with drums for $150. I'm assuming a 3.73 shouldn't be hard to find and bolts right up. I know I'd need to address the speedometer/odometer with the new ratio. Are the clusters adjustable for this, or would I need to pull one from the donor truck to get accurate readings?
I appreciate your time and input!
The 3.0 likes to rev, it's a car engine. So no down low torque. 3.73 or 4.10 would help. It doesn't change your legal tow limit though. But I've never paid too much attention to that limit as regards to a manual transmission. I think the manufacturers is covering their ass re: warranty claims by people that don't know how to start off with a clutch without slipping it and burning up the lining. You can achieve the same result by putting on smaller diameter tires. It might look funny but much less work. And it will let you know if a gear change is worth the trouble.
If the donor axle is from a truck at least through 1994, just also grab the plastic gear on the lower end of the speedometer cable.
Earlier trucks used mechanical speedometers, with a gear-driven cable. The gears have different tooth counts (in different colors to identify them), to accommodate the different rear axle gearing ratios. If you also get that gear out of the new axle donor truck, and replace your current one with it, that should take care of changing the speedometer to read correctly with new axle.
It'll be just one bolt, and one circlip to nab the needed gear from the donor.
So the difference between 1800 and 3700 is the transmission? I knew there was big difference but that's wild in a 3.0 truck. Especially since it's the same transmission in the 4.0 manual.
Here's the 93 chart:
I wish those 4.10 front differentials from 93 weren't hybrids. Even so if I stumbled upon one with the inner stubs, I might still use it.
I wonder what Ford would've put for a 4x4 supercab 4.0 with 4.10s?
Full size chart for LULZ.
So a regular cab 2wd auto 4.0 Ranger with 3.55 is almost the same tow rating as a 4x4 auto 7.3 F350. One of those ratings seems wrong.
If you're going to swap it out, get the 4.10 gears. You'll enjoy driving the truck a lot more in all conditions. Everybody else covered the important parts. Swapping the speedo gear at the transmission is easy.
This.
If you're changing gears, just put 4.10s in. Limited slip if whole donor axle. 8.8 if you're feeling especially frisky and can be down for a few days wrenching on dumb shit like brake lines.
Fuel economy will mildly suffer. Drivablity will not.
I've swapped gears once, and swapped axles once. Axle swap was easier.
My first Ranger was a 3.0, manual transmission, 2wd with 3.73 gears. I frequently worked that truck. The biggest problem is that the 3.0 doesn’t produce much low end torque and the first gear ratio in the M5OD is a little too high. Really think 3.73 or 4.10 gears is where you need to be. Personally I highly recommend finding an 8.8” limited slip rear axle and swap it in.
As to the whole rated towing capacity, I find those numbers a little absurd. The reason they downrate the manual transmission so much is that they don’t want someone trashing the clutch or something and then complaining. Technically because of the manual transmission in my F-150 it’s rated to tow less than my 4.0 Ranger with an automatic. That’s dumb.
Thanks again for the help! Sounds like the truck can handle 2,000 lbs fine but an axle swap is the better long-term play. From what I've gathered, the 4.10 is best for towing and the 3.73 is a solid middle ground. For either ratio the limited slip is the way to go if I can find one.
The axle guide mentions the 4.10 may require modifications to swap in. Does anyone know if that's true in this case, and does the 3.73 swap more cleanly? I'd rather have a bolt-on swap than deal with modifications, so I'd lean toward the 3.73 if it's simpler.
Not sure what they could be talking about that it’s not a bolt-in swap. The only issues I’ve run into with swapping rear axles has been there’s a couple different U-joint yokes depending on the year and axle options (easy enough to remedy) and the other is when you’re swapping like an Explorer axle and the spring perches aren’t right. The whole driveshaft U-joint yoke thing doesn’t seem to be related to gear ratio, but rather what year and what driveshaft. There were two different U-joint sizes typically and two different yoke bolt patterns for each of those. Match up what you need and swap yokes if you have to.
No. It's not the gear ratio that requires modifications. It's using axles from other vehicles or years that are greatly different from ypur year/model. For example, Explorer axles have the spring perch inderneath instead of on top. Swapping from drum to disc brakes takes some fiddling with e-brake cables. Some axles don't have the speed sensor on the diff.
The only modification needed on a 4.10 in a 7.5" axle is when you pull the cross pin, a lot of times the pin hits a ring gear tooth so the easiest option is to dremel a tooth to get the pin out... BTDT.
As far as what axles, as long as you get one from a '93-09 Ranger it should bolt in if it is the complete axle with complete brakes, there's some brake changes over the years and some things can get complicated as the center hub on the axle changed a little bit around '02 I think...
I went from 3.45 to 4.10 in a 2.3 longbed. Highly recommend!
Did a 2001 8.8 axle into a 1997 7.5 truck... wasn't too bad. Just normal brake line stuff.
Remember to order rear brakes for the axle, not the truck. Caused some confusion when I tried to put brakes on.
7.5 in with stock 4.10s exist, the 2.3 4wd models came stock with them, at least the one I have did.
The 4.10 axle I sourced came from a 2.5 2wd, was a 7.5.
If you have a UPAP near you, they are dirt cheap for different, or at least used to be. I think I was paying like $60-80 for them. Would have been stripping them more often if they were cheap to ship.
