which weld process for bed/fender work?
Why not leave a little extra material around the edges and use panel adhesive? It's a standard practice these days.
with a couple screws to initially hold it in place so I can either glue or screw it?
My only TIG experience is with my multi process welder, it's only capable of DC scratch start TIG and the wand just has a gas knob, I can see where a pedal and high frequency start would be huge game changers...
For years I was stuck with flux core and stick welders, I learned some dumb tricks with flux core because of course I had the worst option for a flux welder the old 90A Chicago Electric that is on AC! Did a dumb amount with that then got spoiled with the DC welders then got gas and that is magical... way less cleanup.
You can generate too much heat with grinding too and add to the waviness.
Flap disks and sanders put less heat into steel than a grinding disk
now all I need is the manual, hope it has lots of pics :icon_welder:
the MIG is a lot easier, just crank it up and let the sparks fly.
