- Apr 3, 2021
- Phoenix, AZ
Cool. Thanks for all the information. Need to practice some more on flaring. I'll follow up
I got one of those from jegs when I redid my F150 lines. worked really well.what size line?
the titan is the best one for the money.
Titan Tools Double Flaring Brake Line Tools, 45 Degree 1/4 & 3/16 | eBay
It makes SAE Double Flares, For use on steel, nickel, and copper tube, Designed to be used in the tightest of areas to repair a brake line, Handle can be removed and the head of the tool can be mounted in a bench vise so you can make several flares with ease, The handle can be removed.www.ebay.com
great deal...
Just recently started practicing with the Auto Zone loaner tool.Cool. Thanks for all the information. Need to practice some more on flaring. I'll follow up
1. Yes, you need to use a quality tubing cutter and take your time with it. It makes getting a good square cut easier, which is important for any flaring. I tried a Pittsburgh cutter from Harbor Freight and a Performance Tool before moving on. Now I use a Rigid and a Lennox.I practiced brake line flaring again tonight. I decided not to post a pic yet because....well.....to be honest, my flares just aren't up to snuff yet. The flare still is still a bit crooked and not good 90 degrees offset from tube.
I made a few observations in areas that I think are holding me back.
1. I was using one of those mini tubing cutters. The little cutting wheel cuts at a slant.
I am switching to a better quality small pipe cutter I have in my tool cabinet.
2. When you crank down the yoke from the flaring kit, the tapered point wobbles when it presses into the brake line tube
I mean the thing really has significant play. And it is a brand new kit. I am the first user. So I'll hold the tapered point in place
while I crank the yoke.
3. I am cutting small lengths of practice tubing from a 25 foot roll of coiled brake line. So it already has some curve bent in. What is the best way to straighten out rolled pliable poly steel brake line.......with hand tool ?
I've never used lubricant. If I ever decide to use some, it will not be anti-sieze. That stuff is miserable to clean up. A little wheel bearing grease should be fine.Oh Geez......Through all these practice runs I forgot to use lubricant !
Is that part of the problem ?
I watched a YouTube guy using anti-seize lubricant.
