PlumCrazy's Beater DD 4x4 SAS Build
No no. I snagged another one a few years back.
I just need this pile to stay running for a few more weeks...but it sure acts like it wants to be done now.
Spent all day Sunday at my brother's house prepping the engine and trans to go back into his Lexus...when it was time to leave it struggled to start, then died.
No pressure at the fuel rail, the fuel pump relay was clicking, but the pump wasn't humming. Towed it home and put power straight to the pump and it made a slight hum, but no flow. Reversed the polarity and it ran backwards...flipped back to proper direction and it started pumping. lol
IDK if something made it past the sock and jammed it up or what, but its running now so that's a future me problem. I ordered a pump and sock to swap in when I have time though. In the mean time Ill keep my alligator clips and a Dewalt battery in the truck to unstick it if needed.
for sure compromised sock......more problems inbound.
What is frustrating is that I put a fresh pump and sock in when I swapped to the stainless pump hanger/sending unit back in September when I had the tank out. Lol
But….I also ran it out of gas once and probably upset the pump. The sending unit / float aren’t right apparently and it ran out of gas at just under 1/4 tank according to the gauge, but took at full 16.5 to fill it, so she was empty for sure.
Pulled the pump and swapped in another freshy. This time I specifically looked for one with a mesh inlet screen.
Cut open the sock and didn't find any smoking guns
Tweaked the float rod and tossed it back in with a new sock.
Snipped a cover out of the parts rig.
Scuffed and drenched it in paint
PS. If cutting a hole in the bed upsets you....take a gander at the rest of the rig.....
the bed benefits from all sorts of floor access ports.
Snagged another seat meh condition Alcoas with some KO2's what the center caps alone are worth. Tires are weathered, but fine for the back roads this truck sees.
Gatta keep your loved ones buckled up for safety.
My first set of 35's, I picked them up in a 2 door Justy... I tried everything, they wouldn't all fit in there with room for me so I had to strap one to the roof...
My best was a set of 265s on Steel Super Duty wheels into my CRX lol. No passenger and all 4 mudflaps dragging for 120 miles lol
