Heater core bypass valves?
rusty ol ranger
2.9 Mafia-Don
⭐Supporting Member
Michigan
86 Bronco II
My blend door lever is broke tottally.
I was pulling dash to replace the box but i have a question...
If i set the blend door to heat and install a couple shut off valves on the heater hoses....would i need to install some kind of bypass for when the valves are closed?
If you did have to do a bypass you could prolly rig something using like a 3-way ball valve? But then I'm not sure where you would install them. Easiest is under the hood but then...
I found a cable operated one....im wondering if i can rig it up to the factory controls...
The later Rangers had vacuum operated heater bypass valves. Some had a single valve and some had the double valve, the double valve sends flow back to the motor and the singles don’t. I’ve been debating on rigging one up in my older stuff. On the newer stuff those only operate when you’re in the Max A/C setting and I’ve been debating if I want to try and modify it to be able to activate it whenever I want. Just that’s considered an additional creature comfort thing and I’m still trying to deal with the more important stuff
Mine broke the actual piece that attaches to the blend door. It was stuck inbetween hot and cold. So all summer it was hot then winter i had no heat lol.
Mine broke many years ago. Supposedly the default setting is heat on. Mine is hot air only. AC died many years ago as well, so I am back to being an old school windows down type. Which I prefer anyways. I'll even roll around in the winter with the windows down and the heat on full blast.
I get that, I was talking about the valves on the heater lines.
I don’t know if the blend door will stay put if it’s broken, might be something that needs fixed. My thought with the valve was more that I could remove the heater core from the equation if I’m trying to maximize AC function in the summer without using the Max AC setting or if I wanted to just bring outside air in through the vents without the heater core warming the air or the AC running. Just an idea that’s been rattling around in my head for awhile, lol
Ah i gotcha.
The semi runs those valves that are supposed to help with AC operation by shutting off heater core...honestly it makes no difference. I leave mine open because we have days where you want heat in the morning then later on ac.
Im going to go out today and see if its possible to wrestle the heater box out from under the dash...im not very hopeful though
Ah i gotcha.
Ag tractors have them too, mainly IH for some reason. Something else to leak and I don't think they make any difference.
I used this exact kit in my 88. Its a non-AC truck so anything I can do to remove heat from the cabin helps. Having a 200* chunk of copper/aluminum in the dash whether air is moving across it or not isn't ideal in the summer...but mornings like this morning when I came out to a heavy frost, its nice to just pull the knob and have heat when I need it.
Not the best picture of it, but I did the install when I replacing the leaky heater core. It made it pretty easy to sneak the cable through the firewall with one if the heater core barbs. I think I just drilled a 1/4 hole in the HVAC plenum with a long drill bit from the engine bay side while the core was out. I put thick heat shrink arounf the cable so it wouldnt rub the heater core tank.
I will look for pics of cable routing...I did it during my hiatus from documenting stuff
Eh i just ordered a box.
Itll give me an excuse to replace other shit that needs replacing in there as well.
What speakers fit up by the windsheild with the factory metal grills?
Little ones....IDK...windows down with no AC... nothing that fits in the dash is loud enough to matter from my experience
Lol...
Mine were cackly....then when i pulled them out i seen the tops of them were totally dried out and sunbaked
