lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
I’m not sure what the engineers were trying to achieve with that. The 98-00 4x4 trucks typically had a two piece upper control arm on the passenger side. The inner piece of that set is unobtanium. Later years and most aftermarket sells a one-piece upper for those. I guess the adjustable lower was a 2wd thing. Ford has a habit of doing strange things.Just finished redoing suspension on my 98 2.5, plus all 4 new shocks. Ride feels like a nervous foul on a new patch of grass. Dang.
I too received the wrong LCA from Amazon though it clearly states they fit. I reused the old ones and pressed in new bushings. Those were a pita but my neighbor buddy came through with his hydraulic press made it ez pz (I swear am buying or building one of those.) Incidentally I didn't encounter the dreaded bolt hitting the cats that I have heard about. My only thing was nobody warned me about the passenger side LCA rear bolt being a camber type. That wheel has it's own true North. What's the use of this 3rd camber bolt, actually what's the use of 5 total camber bolts in this ranger?
