- Nov 20, 2001
- Wayne, PA
- Tire Size
- 42
I'd look to see if the transmission controller wiring is good too, loose brake wire freaking out the transmission controller
The ignition switch thing is interesting....seeing as how someone has been into the column...im assuming by the fact the plastic surround is fucked up.
I would trade it for jets and a float lol.M
Kinda smells like a theft recovery... lingering issues from could be an issue as well.
LED's should pull way less current than normal lights, not more. If they are popping breakers because of load incandescent lights wouldn't have a chance.
All I know... right now I wouldn't trade my plate of noodles for your plate of noodles.![]()
Im not holding my breathIt fixed itself!
I love it when they do that.![]()
I did look into it.dont forget the t 56 swap....
errr...i mean t18
or 3650.....
Well, my wife and my buddy coordinated buying a cheap Grand Marq for my birthday.
Been tossing around the idea of building a big bodied drift car....and apparently she was listening. lol
Title was signed over to friend's shop due to cost of repairs and it just sat there for a few months. Needed an intake manifold (common 4.6 issue) and had some weird electrical issue. It would over charge, not charge, peg the temp gauge randomly and shut off randomly as well as a bad air ride compressor....but it is a rust free V8 car and I was able to drive it home.
Started by replacing the intake...
- PlumCrazy
- Forum: Other Vehicles
all the kewlz kidz are doin it.
dont spend money on that yet...get the code on the ecm...i will see if i have one you can use.I did look into it.
Anyways that said....i apperciate the help. I found a place in toledo that can test (and rebuild if bad) the PCM. If its not bad its an 85 dollar test fee. I think at somepoint soon im going to yank it and get it tested so i can atleast stop chasing my tail. They seem to have a pretty good reputation as well.
Unless im missing something...but i spent hours over last few days looking at everything i could and testing what i could test. Everything seems A ok.
Two days in a row now its ran fairly well.
Ill still have to spend 175 to get the PATS programmed....unless you know a work arounddont spend money on that yet...get the code on the ecm...i will see if i have one you can use.
