lead acid to lithium battery swap
california
2.5L
stock
i vanlife and charge a lot of my stuff off my lead acid battery and killed another one after only three years. i was suggested replacing with a lithium ion battery, as they are now cheaper than lead acid.
the only caveat is that they require a Battery Management System. are the LiO batteries with the bms cheaper?
  • lead acid to lithium battery swap
I don't want to sound negative but I would be very careful with batteries like that for a few reasons. I don't think automotive lithium tech has advanced far enough that a safe lithium car battery will be cheaper than lead acid.
I helped a friend spec out a marine system and I found troubling inconsistencies between sales brochures and data sheets. The battery my friend wanted to use bragged about having a "built in BMS for safety" but when you dug through the tech specs it required an (expensive) external regulator to protect the battery. When he contacted their sales they said "no, the alternator regulator isn't enough, it needs very stable power for charging". And this wasn't cheap Amazon stuff, it was quality marine -grade gear.
Just be really certain of what you're buying and I'd say resist the temptation to go too low on price with lithium - there's just too much dangerous junk out there IMHO. If you need durability that's definitely compatible with vehicle 12v systems, consider an AGM or deep cycle battery depending on your exact use case. Yeah, they're not super cheap but they'll survive deep discharges much better than normal starter batteries.
Yeah, deep cycle batteries are what you need for constant discharge/recharge. Also, no automotive batteries seem to last very long anymore. It’s becoming a problem.
As for cheap Lithium batteries, I’ve seen where people have cut them open to find nothing but rows and rows of cheap like 18650 batteries linked together.
This is my main worry, especially when you realize how the market is flooded with low quality and counterfeit cells. You could build one like that with real LG or Samsung cells and a proper BMS but it wouldn't cost $80, it would cost $500
can a deep cycle battery that fits the 2000 2.5l ranger be bought at a super walmart? tractor supply co or any other common place?
I've actually been researching this a little bit recently myself, and these are some things I've come to find so far:
12V lithium batteries made for vehicle use are not Li-Ion, but rather LiFePO4 (lithium-iron), which is a far less volatile chemistry than Li-Ion.
Four 3.2V nominal (3.6V fully-charged) LiFePO4 cells match up well to sub for a six-cell lead-acid unit.
Lithium batteries of both types cannot tolerate heat well (above 140°F), so not a good choice for under the hood (this limits their use mainly as an auxiliary or "house" battery mounted inside the cabin space or someplace away from the engine).
Lithium batteries cannot be charged if it's 32°F or below (some batteries will activate a built-in self-heating coil when charge voltage is applied, but actual charging won't begin until it's internal temp rises to like 35° or so).
Lithium should outlast lead-acid if it's kept at the right state-of-charge (SoC) level as much as possible (between 50-70%, which is different from lead-acid which lasts longest when maintained at 100% charge).
LiFePO4 batteries should not be paralleled with lead-acid, even with using a relay isolator (if one battery has a very different SoC than the other, can cause a potentially damaging current flow to occur between them when the relay activates). A DC-DC charging system should be used (of course solar can be used with it as well).
That is pretty much is how all EV batteries are currently built, although it appears the cells are up around 38120 (size) now.
Some very early EV batteries I understand originally did use 18650s... That's a lot of freaking cells to build a 60-80kWh battery out of (each 18650 cell I think is like 8-9Wh, so close to 10,000 cells!! :eek: ).
Smaller batteries like what is being discussed here are going to have a similar type of construction.
I'm not sure what is holding them back from producing larger cells (ones that hold around 100-200Ah each for an EV battery)... Seems like it would be a lot easier & cheaper to string 1/10th as many of those in series than the same number of "cells" each one consisting of a dozen or so smaller cells in parallel...
You may have to modify or replace your battery tray (the '98-'00 trucks (maybe up to '11?) have tiny little trays), but by doing that it should be possible to get a grp-27 under there...
I managed to get a 27 under the hood of my '94 with a bit of modification to the underside of the hood from a hammer.
You live/camp out of your vehicle a lot? Do you have a solar panel setup on it?
For the record, the marine setup I mentioned was LiFePO4, and your research is in line with what I've seen too.
My theory on why they use discrete cells to build bigger packs rather than custom cells is economies of scale. I'm not sure how many batteries are used in Teslas compared to disposable vapes worldwide, but I'm pretty sure the vapes are why the market is flooded with counterfeit batteries. 🙂 (Why would you put a $5 cell in something that's going to get thrown away in a couple days?)
There are undoubtedly other advantages - it's easier and safer to regulate the temperature of smaller cells for example. However, you get the disadvantage of losing the whole pack when a certain number of cells goes bad.
@4x4junkie brings up a good point about the battery trays. 98-11 got tiny trays. Both my 89 Choptop and 92 Ranger got 65 series batteries and there’s still room in those trays. My 00s didn’t have room for much, even trying to modify the tray. When I did my 5.0 swap in my green
Ranger I decided to try fitting the battery tray out of the donor Explorer since it was big enough for a 65 series. Turns out a tray out of at least a 97-01 Explorer with the 5.0 (probably all 96-01 Explorers but I haven’t verified) fits with minimal modifications. I had to relocate my horn (in mine it’s between the inner fender and plastic fender liner, I was able to move it over some and keep it in the same general location) and I had to do some minor modifications to the inner fender but if I would have had a riv-nut tool then, I could have done it all with just pulling the plastic fender liner.
I did end up replacing the one grounding stud on the core support with a bolt and put a little bend in the ABS mount to give a little extra breathing room for the battery. The Explorer tray is a plastic tray. I’m thinking of doing this mod to all 98-11 trucks I end up owning because it simplifies my fleet. 65 series is also what the dump truck and F-150 use. My farm tractor and lawn tractor are the only things that will use a different battery.
The way how you immediately brought up the dangers of lithium batteries is why I commented.
Li-Ion (LiCoO2) is the more-common type of lithium battery, and is the one that can go into thermal runaway (catch fire) if a cell is overcharged or there is a defect within the cell.
LiFePO4 doesn't have this characteristic, so it is a much safer battery to have around. It is also what EV makers have been gravitating toward because of the virulent vehicle fires we've already seen in the news about Teslas and other cars when they catch fire.
https://en.wikipedia.org/wiki/Lithium_iron_phosphate_battery#Safety
It may be possible that the documentation you found for your friend's setup was confusing the two types.
I'm afraid I left room in my comment for misinterpretation - sorry about that. I never meant to imply that LiFePO4 batteries aren't safe. What I was trying to say what that given current cell prices and the cost of a proper BMS to charge a pack that can supply 500+ amps, it's not possible to build a proper LiFePO4 car battery for the $85 as shown in that Amazon screenshot. I was trying to say that at $85, you really have no idea what's in that yellow box, and _that_ would be my concern - not LiFePO4 batteries in general.
If you know of a high quality, safe LiFePO4 car battery I can get for $85, please let me know, I'll buy 100 of them today. 😉
Sorry for the misunderstanding.
I run this in my 05 4.0, batteryhookup is a very very good site to get stuff to do with lithium batteries, I also have a 80ah lto bank that I haven't installed yet for my system that I only run a balancer on and no bms due to the amperage that I need. No bms can handle 1k amp draw that i know of for my two orion HCCA 3000.1dsplx amps that I run. But here the major thing you need to consider, unless you get a battery like I linked that is meant and designed by a oem car manufacturer to be under the hood. You don't want ryan, that under the hood due to the heat. Because the oem batteries like the one I linked are designed and tested for it.Among other things
You are correct halfway yes not good for under hood unless you get one that comes in a car such as jags,bmw,etc that was designed and tested by said companies to be for under the hood.
But as far as the cold part goes, it depends on battery chemistry,
Ex LTO can be charged and discharged to -30f
Sodium ion cells can ve charged and discharged to -10f.
them are two examples of honesty i.m.o. the most powerful and harsh condition handling battery chemistrys that is on the market.
No problem.
I believe most (if not all) commercially-made LiFePO4 batteries sold for 12V use have a BMS already built into them (some also have internal heaters the BMS will activate if it's too cold). I've seen them for around $180-250 for non-heated 100Ah units, maybe $50-70 or so additional for self-heated ones.
LiFePO4 appears to have reached similar $/Wh as AGM lead-acid... It's certainly to a point where it can be a practical consideration for an average budget on a camping / overland / RV rig aux battery.
Was specifically speaking of LiFePO4 (and is also true for LiCoO2), charging them at temps below 32°F can cause lithium "dendrites" to form that may eventually puncture the electrolyte layer and cause a short within the cell (and possible fire if it's a LiCoO2 cell).
No problem. I believe most (if not all) commercially-made LiFePO4 batteries sold for 12V use have a BMS already built into them (some also have internal heaters the BMS will activate if it's too cold). I've seen them for around $180-250 for non-heated 100Ah units, maybe $50-70 or so additional for self-heated ones. LiFePO4 appears to have reached similar $/Wh as AGM lead-acid... It's certainly to a point where it can be a practical consideration for an average budget on a camping / overland / RV rig aux battery. Was specifically speaking of LiFePO4 (and is also true for LiCoO2), charging them at temps below 32°F can cause lithium "dendrites" to form that may eventually puncture the electrolyte layer and cause a short within the cell (and possible fire if it's a LiCoO2 cell).
Had one of these cells vent on me due to faulty voltage regulator in alt, when it did i tried to remove cables from bank. It sparked and thought i could cast magic for a second and learned fireball. Stared the shit out of me, my bank was in the back of the car. It was a hatchback, thank God I could get to the bank quick enough and get the cables removed before it popped more cells. It was already swelling, even with compression. It was, i'm going to be very bad if i wouldn't have got to it in time. Didn't think it was possible for that to even happen but it did
Also you know your shit when it comes to batteries, you work in the field or just tinker and like to build things that could kill you if you are stupid. I'm the latter half of that statement but I do work in the electrical and controls field so goes hand in hand
I think we're all basically on the same page here - I think it's a new and interesting topic though so I just wanted to add a thought or two in the interest of learning, since I've seen a few people on the forum interested in trying out new battery tech. Seems some of you guys have first hand experience with lithium in vehicles - mine comes from other applications, mainly consumer electronics.
One reason I've seen people typically offer for wanting to try lithium batteries is that they're tired of killing lead acid batteries with deep discharges. One thing about battery management systems is that they're supposed to protect the cells against overcharging and over-discharging, and the ones I've worked with usually do a pretty good job of that. Some BMS however, will blow a fuse (either a physical fuse or a software fuse) if they don't like the state of charge of one or more cells, especially if a cell voltage drops too low. This often leads to a battery that is essentially dead. My point is just that while lithium-anything batteries have a great power density, they aren't necessarily a magical solution to, say, leaving your headlights on.
I'm curious if any of you guys that have used lithium in automotive applications have dealt with BMS issues.
P.S. I think I give the impression sometimes that I'm a grump and a technophobe. I'm really not, I work with tech like this every day and I enjoy it. I guess I just prefer simple solutions to simple problems whenever possible. 🙂
