hi im devo
Toronto
ON - CAN
Vehicle
Drive
5
this is my turbo ranger
88 thunderbird engine
GM8 turbo
front mount intercooler
forward facing upper intake manifold
ebay manifold (#2)
3'' exhaust
sectioned oil pan
QA1 front shocks w/ lowering springs
Ricks Rangerz Frame Notch
Billstein rear shocks
F150 leaf springs
235/60/14
Volvo lip
fiberglass bed sides
Sparco racing seats (expired last year)
Manual boost controller
Catch can
Roof leaks
mirrors fold in on the highway :/
transmission sounds like rocks
hi im devo
hi im devo
hi im devo
hi im devo
hi im devo
hi im devo
hi im devo
hi im devo
Welcome to TRS. Thats a rad little trucks. Bet it's a blast to drive.
gm8.... i can see it being useful for a 2.3.
not so much for my 6.5.
I like it.
Welcome to TRS.
I dig it, probably would have done a couple things different but I like the '89-92's! Good ol turbo 2.3L's!
For the mirrors if you take them off and grind off the pot metal peened over the spring then drill/tap the posts for like a #6 or #8 machine screw to tighten up the pivots that will take care of that.
If you set all that up rebuilding the M5OD is fairly trivial, kits are cheap or find a replacement from a ~87 through '97 2.3L and you'd be good...
welcome!!! sweet truck
Hi! Sweet truck! 😎
GM8 turbo
ebay manifold (#2)
3'' exhaust
sectioned oil pan
F150 leaf springs
235/60/14
Volvo lip
Catch can
Roof leaks
View attachment 140481View attachment 140482View attachment 140483View attachment 140484
Way cool!
But one question…
….will it GO?
1. Personally, I don’t like to modify my trucks more than routine maintenance improvements.
2. Don’t underestimate the cosmetic appeal of carefully applied rustoleum with a foam roller.
3. If you buy a membership for a whopping $15, you can get rid of all the pop-up ads while supporting the cause.
4. And no matter how cool your truck is, you’re still new to TRS. You’ll have to get one of these and wear it to all events for the first year and then request an upgrade.
hi im devo
WELCOME ABOARD!
Way cool!
But one question…
….will it GO?
Right, all rangers get a routine maintenance extra rear axle, just standard procedure :)
