Horrible headlights
Can you have lights on with ur headlights or is it illegal
Foglights on with low beam. They have to be lower than headlights to count as foglights.
The combination would be powerful as a legal upgrade here. You could have 4 high beams, and your 2 low beams with fog lights.
What do you mean 4 highs? I have a 94 ranger with no fogs
Yeah they are clear lenses
Are they OEM? (do they have the Ford ovals on them?)
If they are OEM (and not hazed/yellowed from the sun) then ×2 on checking their aim.
I always had thought the headlights on my 1994 were pretty good... It's the headlights on my 1990 that really suck donkey turds (I have two sets of auxiliary light on it, one Driving light set (basically same as two extra high-beams) and one Fog light set).
4 lights on with the high beam. You could in theory get a pair of 7" round or 5"x7" motorcycle housings and use headlights with dual beam in each. In addition to your factory lights. I see no reason that would be a problem. I am not a lawyer tho.
They are oem
Oh ok thank you
For the sake of other drivers just don't get those dang yellow round laser beams people are running recently!!!!!!!!!!!!!!!! Those things can blind oncoming traffic in broad daylight, why they leave them on all the time is beyond me...
Yea I just want more light fo country driving
Whatever you decide to do, it's best to run a relay with any added lighting. Ford made the stock wiring barely big enough to supply the stock lighting. And you can add a relay for the stock headlights also like someone mentioned. It will make the stock lighting brighter, no other changes. The stock wiring is that small.
My wife's 86 S10 went from barely making the filament glow to comparable to her 16 Versa with just a relay kit and GE Nighthawk bulbs.
