Horrible headlights
1994xlt
Forum Member
Morton
IL - USA
Vehicle
Drive
Stock
Stock
good question
I got a 94 ranger and I’m figuring out why everybody always put light bars or roof rack lights or whatever you wanted but like any old truck has additional headlights because even compared to a newer style headlight setup non led they suck there isn’t no projection with them. I put in new bulbs and there better but not by much like in my opinion the brights on is what I want my normal headlights to be but anyway do I put a light bar on it? Or is somthing like adding auxiliary lights a better idea like driving lights from farm and fleet
Horrible headlights
I think I would work with the stock headlights a little more. I have found through the years adjustment can make a big difference in how they work.
I discovered by accident on one vehicle I have, the headlights were actually adjusted too high, making vision poor. They were shining out and up too far, not hitting anything directly. I discovered this by accident, driving on a trip in terrible fog. I could not hardly see anything, but when a car would pass me in the left lane, I could see fine when their lights were shining. Lowered them down and they worked better in all situations.
Also in my state we have inspections. All lighting has to have the DOT label on it, and no aux lighting can be above the stock headlights. If it is offroad lighting above the headlights, on road it has to be covered. I don't care what you do if you hook your lighting up to the high beam switch, but please be mindful of other drivers with extra lighting in low beam mode.
Okay these ones say dot certified so is it ok to run them?
Another possibility is to run new wiring to your lights using your stock wiring to a relay to control the lights. Apparently that can really help.
Is it @gaz that has some knowledge on this?
I thought we had a tech article on that. But a quick look isn't turning it up. I could draw a diagram for it later.
Bronco Graveyard has HD headlight upgrade harnesses. They are cheaper than I can make one, so I’ve bought a couple. Put one of them in my Choptop and went from 9004 to 9007 bulbs, definitely an increase in light output.
Personally, the best bulbs I’ve run are the Sylvania SilverStar and Ultra bulbs. I’ve tried some LED bulbs with mixed results.
If you have round headlights I think it's Toyota has a deal on 2 Kioto glass bulbs and the relay harness to replace the old headlights and harness. This was awhile ago and the price then was about $18.00. I found the same sets up here in Canada for 50 caknucklehead dollars and bought 2 sets.
7" bulbs iirc.
I plan on doing the mod on my Ranger while I have the engine out of the way. I harvested a nice 2 relay box from my Exolorer donor that will work very nicely.
And dumb question here but have you polished the lenses? If they're dull or yellowed that makes them even worse... I also second the Silverstar experience and checking the aiming, that's part of the problem on my '97 as they are aimed too high...
I don't know the swapover year between 9004 and 9007, I just know my '90 has 9004's and all my others ('97 Ranger, '98 and '00 Explorer and '97 F350) are 9007
Yeah they are clear lenses
I got silver stars in there now
IDK what the laws are like where you're at but here you are allowed 4 separate headlights.
Like this:
Horrible headlights
BTW, that is @Rick W 's ride. The Missing Linc
On top of the cab has to be offroad use only. The 4 in the grill can all be headlights on the road.
