Type F or is there a better PS fluid?
MaD
Forum Member
AZ
Putting in a new power steering pump and used steering box. The previous one whined loud as hell so I'm hoping this one is quieter. Should I use type F as suggested or is there a better fluid?
Use what the book calls for, be sure to turn it lock to lock several times to get the air bled out of the system.
  • Like
Reactions: MaD
i have heard that putting some friction modifier in with the fluid helps quiet them down some, not sure how true that is or not
  • Like
Reactions: MaD
The big thing is getting the air out of the system. Otherwise the pump will score and you have a whiner forever and ever.
Go by this attachment & it should take care of the whine. It did for me.
This is when installing a new/reman. pump. You can try to correct it with your current pump but
it may be too far gone.
  • Type F or is there a better PS fluid?
I use Mercon in older systems that called for type F because it's slipperier. We used to add friction modifier to quiet down noisy pumps but it's basically putting a bandaid on a bullet wound and doesn't last. Once you've refilled it and turned it lock to lock a few times, try attaching a vacuum hose to the vent on the pump cap- it will pull remaining air out of the system.
