What did YOU do today?
I've been using h&r blockhead for a number of years because I'm lazy and don't want to keep up with last years total or whatever they always ask but I remember it being annoyingly "simplified" which made everything harder... I have a thing I have to use I think it's the K1 form or something so I'm stuck on premium, need to do that this weekend...
Did mine this afternoon. Had to pay state more than my fed refund. That was only about an $80 difference. But then, somehow, "file free with Turbotax" cost $118
Just can't win.
Turbo tax is sneaky, you need to make sure you stay on their free option. They tried 3 or 4 times for me this year to upgrade. A new page will load asking to continue with the next tier plan with a "continue" button, and a "back" button. There is a 3rd option that says something like "proceed with basic plan" or "no thanks" that will keep you on the free option.
Brought home a new to me truck today. ‘89 F150 longbed. 300/T-19/3.08/2wd.
Wasnt sure Id like that high rear gear but its turning 2200 @55. I think it will work, Most I will tow would be 4000# and both of of my escapes handled it, Im sure the mighty 300 will.
I had a 92’ with the same set up. I swapped the 3.08 to a 3.55 and I gained 4mpg and a lot of useable power on my regular commute.
Although with that short of a rear gear, it wasn’t great for anything above 55mpg.
I went to 3.55 but also up to 31” tires. That combo has worked well for me.
Got home & drove the front end up on ramps, the ice had melted in the back so going to let it sit & drain. Put a new fuel filter on & dumped 5 gallons of gas in the front tank. brake pedal goes really far down to the floor, noticed it looks like theres been some leakage between the master cyl & the brake booster. Really clean underneath. Last night I ordered a new thermostat for it, saw theres a “208” I could get but I just went with the reg 195.
Did mine 2 weeks ago, always agrevating. this year the wireless mouse wouldn’t work & I hate trying to use the thing on the laptop keyboard for a mouse so I bought a old-school wired mouse. Got enough back to help with a purchase Ive been wanting to make.
A mouse that works?
I bought the brake pedal light switch at advance for $10. It was raining so it’ll have to wait a day or two.
They didn’t have the switch for the parking brake. When I was looking online, I got the same thing on a couple different websites.
That’s the top and bottom of the same screen image. I’m going to have to get upside down and backwards and pull mine out to figure which one it is.
drove the ranger to work
View attachment 139981View attachment 139982
My parking brake switch is loose or out of adjustment. I have to hold the parking brake pedal up with my toe to make the light go out. I just ride around with the dash brake light on all the time.
My parking brake switch is loose or out of adjust ment. I have to hold the parking brake pedal up with my tie to make the light go out. I just rude around with the dash brake light on all the time.
Gosh! Won’t you hang yourself if you have to mash on the emergency break if the regular brakes fail?i
And somehow, I can’t really envision you with a tie on
I fixed the typo. Thank you. That would have been inconvenient.
On a serious note, it led me to a question. I know on some of my other cars that red brake light on the dashboard comes on if the parking brake is on, but it also comes on if there’s problems with the hydraulic part of the brake system. Does the Ranger have any of those safeties? My 87 or my 97? That would be a concern if the light was staying on all the time.
The 97 definitely does.
You’re right about it staying on continuously and I should fix it.
But, i’m under the hood checking/refilling fluids often enough that I know the fluid level. And, in a few weeks, the truck is going inactive for major overhaul and the brake system is in the schedule. So, I may address the parking brake switch at that time, since I’ll be upside-down under the dash for other wiring stuff.
