2.3L ('83-'97) Misfire help
91red
Forum Member
Enoch
CT-USA
Drive
Stock
Stock
Stock
I have a 91 custom with the 2.3 and it’s missing pretty bad barely smooths out with rpm and replaced coils plugs and wires and injectors and fuel pressure regulator and it just won’t fix
Just read on another thread where they fixed a misfire caused by a bad injector connection.
I pulled the whole injector harness and and nothing is is sparking off each other was it the connector that went bad ?
Yes, the catch had broken off and the connector was loose.
Unfortunately, you could still be working with a faulty new part.
With it stumbling, spray something flammable in the throttle somehow to see if it smooths out. If it does there's something else going on with fuel delivery.
You could have a bad coolant sensor also. I think the temp gage and ECU (probably 2 wires) both have their own so your gage would still work.
If that does nothing, throw a timing light on and see if it's holding steady on the damper.
How would I check with a timing light ?
I also forgot to say I put a new timing belt and retimed the motor
Clip the pick-up on the #1 plug wire, depending on what light you have set it at 0 to 20 degrees BTDC and aim it at the crank pulley. Adjust the light until the timing marks are visible and just see if it holds steady.
A miss at idle that goes away with RPM can also be a cylinder with low compression. I would check compression before messing with a timing light
I already did a compression test and all cylinders are great I worked on it until midnight last night trying to narrow it down and 1 and 2 aren’t igniting so I have 2 new coil packs coming to see if it’s that first if it’s not that I’ll be putting in a icm in it as well
what do you mean one and two aren't sparking? That's not how it works... it's a waste spark system, one side of the coil (with respect to the connector) goes to cylinders one and 4 and the other side to 2 and 3, both coil packs fire at the same time and the same cylinders should be connected to the same sides of the coil packs, the front and rear orientation doesn't matter. There's literally just separate ignition systems that fire at the same time, one on each side of the engine, from '89-94 during cranking only the passenger side fired but once running both fired.
If you have plug wires on the wrong spot on the coil packs that can definitely cause a misfire problem.
If there's an issue with the crank sensor usually they cause a stall when hot but there's more than one way to have an issue. I don't hear of too many issues with the DIS module, I've never had one...
Yeah I can unplug the wires for cylinders one and two along with the injector plugs and nothing changes and those spark plug in one and two are soaked
Misfire help
Here's a picture I stole from online which is what the stock coils would look like including the sticker labeling the cylinders, notice 1 and 4 are on one side and 2 and 3 are on the other, make sure both coils are set up like that, you can mix up 1 and 4 or 2 and 3 but NOT the other way.
Unless you have two injectors stuck open the firing order is your problem, heck even the injectors are batch fire combining 1 with 4 and 2 with 3, there shouldn't be anything in common between one and two unless something is wrong...
So I checked all my plug wires and everything is correct I even whipped out the chilton manual and I ended up replacing the crankshaft position sensor because my tach wasn’t holding steady and it’s still missing pretty bad my dad came out and saw me struggling and told me it sounds out of time so I put a timing gun on it and the timing is super retarded so I’m gonna take the balancer back of tomorrow and triple check my timing belt and see if I have the marks lined up if they are I think the notches slipped back on the little rubber thing which is causing my spark to off from the computer thinking my top dead center is somewhere else I’ll update you guys tomorrow
Don't know if it helps or not but a little info on how the system works. The crank sensor gives a signal to the DIS module which sends an rpm signal to the computer to request spark advance through the DIS module to the two coil packs. The tach output is driven by the drivers side coil for some random reason and needs a coil attached to send the signal. The crank sensor has two separate hall effect sensors in it which basically means it sends a square wave signal to the DIS module instead of a full on sine wave like a variable reluctance/mag pickup sensor.
Not a whole lot of that will likely help, the system is pretty robust when it works but with the lack of diagnostics on that era of stuff it makes it hard to figure out what is wrong...
Yeah no kidding it’s hard to figure it out lol I replaced the crank sensor bc the tach was bouncing when I would try and run it and the old one was gross with road grime and everything so it would have eventually needed replaced
