- Mar 9, 2016
- Columbia Missouri
Mdude.....really.
look at the other spots that are plugged.
what i meant, was to flip the connector over and look at it from the pin/box side.
38 is ommited....
if you open that hole...you will then have a space for pin 38.
the connector itself is broken, or the numbers would be present.
28-33 are on the row next to it.
28,29,32,33 are also ommitted....and 27 in the row above that.....clearly.
CLEARLY.
of course....you could just be fawking with us. must be.
otherwise...
how the fawk you managed to pull off the last swap is now a mystery as well.
you are the case of the broken clock....
Look man... the fugging pin 38 , is that wire Im asking about. You dont know what you're talking about since you don't know, why even reply? How did you get all the decorations around your name? Did you buy them to make you look important and feel like you're sombody?dude.....really.
38 is ommited....
CLEARLY.
otherwise...
