PCV Valve on the back of the Valve cover causing a air leak?
Mike92STX
10+ Year Member
Zion,Illinois
Has anyone found a better way to hold the PCV valve in tight enough to avoid a air leak? I have had a check engine light come on and I checked the PCV vale and I was able to move it into the valve cover a little, I also turned the gas cap a couple clicks. I thought I saw something on here about a way to hold it in better than the little notches. I was also wondering if the coolant line is really necessary? If not, what is the best way to eliminate it?
This is on a 2004 Ranger with a 4.0 SOHC .
Have you tried a new rubber bushing for the PCV to seat into?
I don't think that model has a rubber grommet. It's got an o-ring seal on the PCV valve.
Feels like a German design... LOL
Yup. That one’s different.
