90' ranger XLT Hesitates & jerks on acceleration
Orting
OR - USA
Vehicle
Drive
NA
NA
Hi guys I needed to post a thread I'm at a loss., after trying everything I can think of it's time to call for help from y'all.
I have a 1990 Ford Ranger XLT with the 2.9l, 5 speed 2wd. I got it not running and replaced the engine. And it's been such a pain trying to get the kinks worked out.
Problem; Truck hesitating and stuttering under load or acceleration. It feels like it's starving for fuel pressure. Happens when accelerating & usually starts noticably bucking when just shifting into higher gear. It's intermittent and sometimes it barely does it at all and other times it's throwing a complete fit. The higher the gear and lower the RPM / greater the load the worse it gets. Sometimes it's better to "ease" into throttle or back off for a second hold at 3k RPM and then floor it. Never seems to happen at WOT in 1st and 2nd gear. After I do some work it will drive 100% perfect and I'll think I fixed it and then it relapses after a day or two. heat soak and engine temp don't have noticable effect. Sometimes I notice the engine has much better power, throttle response, and overall performance (not hesitating) then I'll drive it later or next day and it's bad again.
ITS DRIVING ME CRAZY AND STEALING MY LIFE lol all the time and $ going into this seemingly simple issue.
No check engine light
Only codes were for TPS and I replaced it with no joy
I replaced the plug wires,
spark plugs with OEM ones gapped to .44
new dizzy cap and rotor
Timed with timing light to 10° BTDC
Tried swapping out distributor with a spare
All grounds verified, sanded to bare metal or replaced
Inertia switch tested normal
Replaced fuel filter
Replaced CTS and coolant flush
No vacuum leaks
Replaced IACV
Replaced TPS
Good battery
MAP sensor checked out
New Injector O-rings
FPR not leaking gas
Removed O2 sensor and drove to check for clogged Cat. (Only time it ever threw a CEL when unplugged)
Some things about the truck;
previous owner scrapped stock air box and ducting & installed a "Hot air" intake cone filter.
No EGR on this year, no MAF either.
The alternator has been changed to a different type I guess I'm not sure, the P.O. did that and hardwired it to harness without a pigtail.
Has the original Catalytic converter with side exit
It's not a misfire
ive removed the AC belt since it doesn't work anyway.
*The fuel filler neck is really dry rotted and cracked. I actyhad to cut a couple inches off the end that mounts to tank just to keep driving it. Definitely doesn't hold vacuum pressure. But no CEL I would think that a fuel system without a seal would be my problem but internet says no.
Also the EECM had the classic fried capacitors which I replaced with ones with the same ratings and higher max temp. But possibly I did a bad job soldering...
All this trial and error and ups and downs of improvements and relapses making me second guess everything.
Any help would be amazing.thank you
I am having a similar issue, but it isn't as "violent" as you describe. Once the engine warms up, it has rhythmic "lope" of normal and reduced speed. these lopes are always equal length of about .75 second, and they will happen during acceleration and holding speed. The engine does not lope when I use the cruise, and it doesn't lope consistently.
What has worked before for me is replacing the computer temp sensor near the thermostat, not the one on the driver side (that one only operates the temp gauge).
The sensor is a bugger to get to. but if you are able to check for voltage and resistance at the sensor, especially if you can't get a resistance reading, That coolant sensor maybe your culprit.
Yeah I made the mistake of replacing the one for the gauge. Which already worked fine. But I recently got one from a parts ranger I have yet to put it in. But I pulled out the vacuum line for my fuel injector pressure regulator and the truck started driving better. Still some jerks in low gear low rpm if I don't take off hard enough. It's running way too Rich now obviously. But I think my issue is the FIPR. I tried using one from the parts truck but the connection is different. I'll follow up once I can afford the part and say if that's what it was.
So I replaced the fuel pressure regulator and it ran better for a little while but is hesitating again. I've noticed I get really bad heat soak vapor lock when I shut it off for a few mins and come back. When I replaced the fuel filter again that improved things a lot but I noticed my fuel pressure was super low as it did not spray me in the face when I disconnected the filter.
I checked with a gauge and sure enough it's at like 18 psi unless I cycle the key a bunch of times. Idk how it's even running tbh.
Its not hesitating nearly as much as it was unless I'm hauling a load. But it does seem to bog down when accelerating. And if it were anyone else they might not notice it bc it drives "pretty good" but 140hp isn't much power and I want every one of those hurse purrs.
So I went ahead and ordered a new fuel pump it should be here on the in a on the 16th which is also my 1 year sober birthday 🎂. (Got the Denzo to avoid any cheap parts issues.)
I'll check back in with the verdict.
  • 90' ranger XLT Hesitates & jerks on acceleration
Yeah that's one of the first things I did replace. I actually accidentally bought the one for the temp gauge first thanks to my not paying enough attention and the O'Reilly's guy being apathetic in his ability to differentiate the two.
Anyway I got the correct CTS and yes it's in a tricky spot without a doubt. I have a special wrench made from chinatium with a bend in it from being used as a cheater. And it so happened to be the perfect tool for that application.
Something strange happened yesterday when I took off my rear bumper to paint the center plate and straighten the corner out...
There was an old trailer plug wired into my tail light harness using those splice clips. And I noticed the ground wire was cut off. Removed all of it for now and didn't think much of it...
Then I had to drive before I reinstalled everything and my truck seemed to run excellent. No jerks save one or two small ones. And very lively, no bogging.(It hasn't been jerking or hesitating hardly at all lately. But has been bogging and low fuel pressure) I'm thinking,"Is this just the weight reduction of the bumper and tow bar? Or could those wires have somehow been interfering with the fuel pump circuit?
Seems unlikely but the wiring config on my truck (different than most) ties into that rear harness and grounds near the tail lights.
I'm probably wrong and my truck was just having a good day again plus the missing weight in the back. So I digress.. I did get my new fuel pump delivered today so tomorrow I'm yanking the bed off again and the liner. To replace one that still works. I'll take a fuel pressure reading before and after and post results and then y'all can decide if I'm crazy or not.
I really doubt the wiring was the issue.
If youre only running 18psi fuel pressure thats most likely it
The wiring was definitely part of the problem. It turns out my hunch was correct. At least partly..
The tail lights share a chassis ground with the fuel pump. (My ranger has only 1 pump.) And the fact that the trailer plug wires were spliced into that circuit without a ground caused a "phantom" voltage draw. My fuel pressure rose to a steady 28 psi up to 32 psi. Still below spec but a noticable improvement. It's so crazy, Ive been tearing my hair out for months trying to find the fault in the wiring of my fuel system. And I stumbled across it by chance. (Proud that I solved it.)
As I stated however, that was just part of it. My new fuel pump was delivered yesterday so I spent the day installing it... I naively decided it'd be easier to drop the tank instead of lifting the bed again since I have bed rail caps and a bed liner installed and no one to help me lift it.
So I spent the entire day having dirt rain down into my eyes while finagling the tank straps and heat shield for FAR longer than expected. I Learned my lesson for sure!
The result?!?
PERFECT FUEL PRESSURE!!! instant throttle response. Idles like a sewing machine. (Besides the PS pump.) No burble sounds. Acceleration is SMOOTH as butter and has more power than I expected. From the low end all the way to the red line it finally runs like it's supposed to. Its night and day. It literally feels like a brand new truck. Which was my goal.
Final list of parts & fixes in pursuit of this gremlin:
-IACV
-TPS
-All ground wires
- CTS
-Motorcraft sparkplugs
-Plug wires
-Distributor
-Cap and rotor
-Fuel pressure regulator
-FPR O-rings
-TB cleaned
-TB gasket
-EECM capacitors replaced
-Coolant flush
-Timing triple checked
-Injector cleaner
-Voltage drop & resistance testing
- probably more I'm forgetting
Congrats!
That's a great feeling isn't it?
Congrats!
Absolutely. It's the highest form of satisfaction outside of the bedroom IMO. Lol.
I bought this truck for $450 with cash I had from selling a tailgate bench I made with an old studebaker tailgate and reclaimed wood. Then I sold a handmade corn hole game for the $350 for the new motor. I've been hustling one way or another for everything I've done to this truck since I got it last July. All while being unemployed.
I actually had real buyers remorse when I got it home and realized how big a turd it was. Ugly, dirty, neglected, lots of little things needed work besides the engine.
I wouldn't have even bought it but I drove so far to get it and had a buddy drive his big diesel and borrow a flatbed trailer from his work. I thought it was 4x4 bc of the stickers on the hub caps. It was advertised to have new brakes/rotors. It did not. Guy swapped out the stereo deck for the cheapest one in existence and just left it on the seat wires hanging out the dash. It had a mini spare on which was conveniently not in the pics nor mentioned. Supposed to have a good battery.. nope. And supposedly just needed a head gasket. Was really cracked heads.
It's turned into a really clean, solid rig that I'm proud of and now I always double take to look at when I'm walking away from it.
Plus, it's finally fun to drive now. Since I'm the type who has to obsessively and compulsively mechanically, analyze anything I'm driving like I'm doing a diag Test drive. And I swear 140hp is a conservative #.
Of course it decides to blow a lower rad hose on me yesterday but I just think it's excited to be back to 100%.
These are some pics of things I made from wood that I turned into my ranger.
That's some beautiful woodworking. If your skills carry over to the truck, it'll be showroom in no time.
Thank you!
Yeah the pic I took of my truck is dirty mid winter. Once the weather gets nicer I'll get it cleaned and buffed and take some good pics of it. Ive done my best to straighten the frowning front bumper and the twisted corner of the rear. I wet sanded the hood but want it repaint it and the roof. One piece at a time.
Really the only complaint I have about this truck is how little space is in the cab. It's so tiny. I used to have a Miata that had more interior storage space.
