90' ranger XLT Hesitates & jerks on acceleration
Orting
OR - USA
Vehicle
Drive
NA
NA
Hi guys I needed to post a thread I'm at a loss., after trying everything I can think of it's time to call for help from y'all.
I have a 1990 Ford Ranger XLT with the 2.9l, 5 speed 2wd. I got it not running and replaced the engine. And it's been such a pain trying to get the kinks worked out.
Problem; Truck hesitating and stuttering under load or acceleration. It feels like it's starving for fuel pressure. Happens when accelerating & usually starts noticably bucking when just shifting into higher gear. It's intermittent and sometimes it barely does it at all and other times it's throwing a complete fit. The higher the gear and lower the RPM / greater the load the worse it gets. Sometimes it's better to "ease" into throttle or back off for a second hold at 3k RPM and then floor it. Never seems to happen at WOT in 1st and 2nd gear. After I do some work it will drive 100% perfect and I'll think I fixed it and then it relapses after a day or two. heat soak and engine temp don't have noticable effect. Sometimes I notice the engine has much better power, throttle response, and overall performance (not hesitating) then I'll drive it later or next day and it's bad again.
ITS DRIVING ME CRAZY AND STEALING MY LIFE lol all the time and $ going into this seemingly simple issue.
No check engine light
Only codes were for TPS and I replaced it with no joy
I replaced the plug wires,
spark plugs with OEM ones gapped to .44
new dizzy cap and rotor
Timed with timing light to 10° BTDC
Tried swapping out distributor with a spare
All grounds verified, sanded to bare metal or replaced
Inertia switch tested normal
Replaced fuel filter
Replaced CTS and coolant flush
No vacuum leaks
Replaced IACV
Replaced TPS
Good battery
MAP sensor checked out
New Injector O-rings
FPR not leaking gas
Removed O2 sensor and drove to check for clogged Cat. (Only time it ever threw a CEL when unplugged)
Some things about the truck;
previous owner scrapped stock air box and ducting & installed a "Hot air" intake cone filter.
No EGR on this year, no MAF either.
The alternator has been changed to a different type I guess I'm not sure, the P.O. did that and hardwired it to harness without a pigtail.
Has the original Catalytic converter with side exit
It's not a misfire
ive removed the AC belt since it doesn't work anyway.
*The fuel filler neck is really dry rotted and cracked. I actyhad to cut a couple inches off the end that mounts to tank just to keep driving it. Definitely doesn't hold vacuum pressure. But no CEL I would think that a fuel system without a seal would be my problem but internet says no.
Also the EECM had the classic fried capacitors which I replaced with ones with the same ratings and higher max temp. But possibly I did a bad job soldering...
All this trial and error and ups and downs of improvements and relapses making me second guess everything.
Any help would be amazing.thank you
I am having a similar issue, but it isn't as "violent" as you describe. Once the engine warms up, it has rhythmic "lope" of normal and reduced speed. these lopes are always equal length of about .75 second, and they will happen during acceleration and holding speed. The engine does not lope when I use the cruise, and it doesn't lope consistently.
What has worked before for me is replacing the computer temp sensor near the thermostat, not the one on the driver side (that one only operates the temp gauge).
The sensor is a bugger to get to. but if you are able to check for voltage and resistance at the sensor, especially if you can't get a resistance reading, That coolant sensor maybe your culprit.
Yeah I made the mistake of replacing the one for the gauge. Which already worked fine. But I recently got one from a parts ranger I have yet to put it in. But I pulled out the vacuum line for my fuel injector pressure regulator and the truck started driving better. Still some jerks in low gear low rpm if I don't take off hard enough. It's running way too Rich now obviously. But I think my issue is the FIPR. I tried using one from the parts truck but the connection is different. I'll follow up once I can afford the part and say if that's what it was.
So I replaced the fuel pressure regulator and it ran better for a little while but is hesitating again. I've noticed I get really bad heat soak vapor lock when I shut it off for a few mins and come back. When I replaced the fuel filter again that improved things a lot but I noticed my fuel pressure was super low as it did not spray me in the face when I disconnected the filter.
I checked with a gauge and sure enough it's at like 18 psi unless I cycle the key a bunch of times. Idk how it's even running tbh.
Its not hesitating nearly as much as it was unless I'm hauling a load. But it does seem to bog down when accelerating. And if it were anyone else they might not notice it bc it drives "pretty good" but 140hp isn't much power and I want every one of those hurse purrs.
So I went ahead and ordered a new fuel pump it should be here on the in a on the 16th which is also my 1 year sober birthday 🎂. (Got the Denzo to avoid any cheap parts issues.)
I'll check back in with the verdict.
  • 90' ranger XLT Hesitates & jerks on acceleration
Yeah that's one of the first things I did replace. I actually accidentally bought the one for the temp gauge first thanks to my not paying enough attention and the O'Reilly's guy being apathetic in his ability to differentiate the two.
Anyway I got the correct CTS and yes it's in a tricky spot without a doubt. I have a special wrench made from chinatium with a bend in it from being used as a cheater. And it so happened to be the perfect tool for that application.
Something strange happened yesterday when I took off my rear bumper to paint the center plate and straighten the corner out...
There was an old trailer plug wired into my tail light harness using those splice clips. And I noticed the ground wire was cut off. Removed all of it for now and didn't think much of it...
Then I had to drive before I reinstalled everything and my truck seemed to run excellent. No jerks save one or two small ones. And very lively, no bogging.(It hasn't been jerking or hesitating hardly at all lately. But has been bogging and low fuel pressure) I'm thinking,"Is this just the weight reduction of the bumper and tow bar? Or could those wires have somehow been interfering with the fuel pump circuit?
Seems unlikely but the wiring config on my truck (different than most) ties into that rear harness and grounds near the tail lights.
I'm probably wrong and my truck was just having a good day again plus the missing weight in the back. So I digress.. I did get my new fuel pump delivered today so tomorrow I'm yanking the bed off again and the liner. To replace one that still works. I'll take a fuel pressure reading before and after and post results and then y'all can decide if I'm crazy or not.
I really doubt the wiring was the issue.
If youre only running 18psi fuel pressure thats most likely it
