Little more power for daily?
Livingston
CA - USA
Vehicle
Drive
I have a 2003 Ranger with a flex fuel 3.0 Vulcan, and I believe a 5r44e transmission. Everything else I know little about. I like to be sure about every little detail so if you think for example I actually have a 5r55e, let me know just for the sake of knowledge.
My question is can I reliably get 450 to maybe even 700hp out of this and still keep it for at least 5 years/200k miles? I am willing to fully tear down the block and start over, but if that's not entirely feasible what can I drop in? As in drop-in ready, I am not super willing to cut things to make it fit. Thanks in advance!
Edit: I'd also like to add 4wd and active suspension, if anybody knows anything about that that would be pretty valuable.
we all like to dream but 450 is way WAY over the top for your engine.
do some searching/reading about what others have done. and hit the Tech Library tab above.
then check your wallet, power/speed costs money. how fast can you afford to go?
since you're in California check into the restrictions they put on modifications.
search for Tom Morana racing
I'm cheap, and drive slow.
I've been reading some stuff but I need to read more. I was hoping someone could tell me for sure what I can do here, because I haven't really found a good setup yet.
You should have a 5r55 trans for that year.
450-700 HP is not a “little” more power. You will likely need a different engine/trans to get that kind of power. Theoretically it may be possible to squeeze that power out of a 3.0, but for the time and money you would be better off moving to a motor that’s better for building power. 2.3l EcoBoost or a V-8.
You could free up a little bit going to an electric fan, electric power steering, and stick a smaller turbo on it, then tune. Not going to hit your HP numbers but it will wake up a bit.
Your transmission can use a shift kit. I put a TransGo kit in one of mine and went almost to the max on any optional stuff. I’m going all the way to max performance when I do another. It wasn’t harsh but it cleaned up all the mushy/slushy shifting. My 92 Ranger with a 4.0 I did a bunch of valve body stuff (A4LD) and that thing would light up the tires from a stop with too much gas and it would chirp second if you were really on it with an empty bed. The trans is where you’re losing a lot of performance. Also, the auto trans shifts too soon for the 3.0 unless you pin the throttle.
I'm going to assume you are talking power at the crankshaft. Your 3.0 was rated 154hp from Ford. To get to 450hp you looking at having to almost triple the stock power. The 3.0 has not been widely pushed to that kind of power. If anyone has tried at all.
To put it another way you would need around 28 psi to make 450. It'll take a metric butt ton of money to build that and have it stay in one piece. And it'd all be custom one off fabrication.
Where did you pick 450-700hp from? Do the numbers just sound good to you? Have you driven something with that kind of power? I've driven a 710hp AWD Hellcat Durango. And I have driven my own ~415hp 331 '93 Mustang GT. My daily is 181hp Bronco Sport. I'm driven a number of other vehicles in the 300-400 hp range.
If you had 350ish hp you would be pleasantly surprised by how useful it is and accessable the power is without being wildly overpowered.
350 or so is very achievable by a number of paths.
No way. Not for a 3.0 in a dd setting. Maybe for a weekend with a huge budget but no way it will see 200k miles under its own power reliably.
5.3 LS out of a truck is a tad over 300hp to start off with IIRC. Adding 100 to that isn't really rocket science.
4wd swap is not easy if you have a coil spring suspension. Basically a solid axle swap which will require a 4wd transmission.
Active suspension? Like IRS or computer controlled stuff?
Can I ask how old you are and what your experience level is with modification to vehicles?
In my 52 years I have seen many a post like this and it's almost always a younger or inexperienced guy that's just getting started and not yet aware of the total effort required to hit a number. The bigger the number the bigger the effort.
I was there at one point and I am still there on some things.
But y'all are forgetting about this miracle of engine performance technology:
Ads on the internet wouldn't lie, would they?
I had dreams of improving my 3.0 for almost 10 years. So, finally, FINALLY after all those years….
I’m doing a 5.0swap.
I was thinking of at least swapping to torsion bar suspension since it's easier to work with. But yeah I would like to know my options for computer controlled suspension.
19, and that's definitely me. Young and dumb lol
I was thinking of that too, how would that fit though?
It's snug. But it fits. The Explorers share the same basic chassis design and they came with an optional 5.0l. There are differences, but... it works. Especially if you stay in the same generation, it's not a bad swap. My Ranger is a 93. That's a third generation Ranger. But it transfers more equally with a first generation Explorer. Since my donor Explorer is a 2nd generation, it has some wiring changes and a few minor mechanical differences. Nothing that can't be overcome. I'm having fun working through it. You can use 5.0s from other vehicles. But you really need the front end brackets (alternator, power steerung, AC compressor and tebsioner pulley) from the Explorer because they keep all those accessories closer to the block so it fits in the short RBV engine bay. Otherwise, your radiator and AC condensor push through the grill.
Coil overs are better than torsion bars. If you’re swapping suspension, that’s the answer most likely. Far more adjustable than torsion bars and you don’t have those awkward bars extending back below the frame. The mounts for the torsion bars on those trucks is also integrated into the transmission crossmember.
The Explorer 5.0 was designed to fit. It’s still a snug fit, but the Explorers that got the 5.0 (95-01, second gen Explorer) were based on the Ranger chassis, although weirdly they had suspension like the 98-11 Ranger with a front clip similar to the 93-97 Ranger. Anyway, the engine bay is essentially the same as the Ranger. I’ve done two of those swaps so far (00 Explorer to 00 Ranger both times). In the 98-00 Ranger, a 99-01 Explorer donor becomes very close to a drop in swap.
The downside is that it’s all old tech and there are better motors to build nowadays so if you’re after performance, the 5.0 is not really ideal. It is a reliable V-8 that can be built. An LS is arguably cheaper to build up. A 2.3 EcoBoost with a tune and some upgrades will spank a stock 5.0, but the 5.0 makes V8 noises and the 2.3 EcoBoost does not.
If youre going this extreme anyways id pass right over the 302 and go for a 351
Go put lower gears in it. my 94 2.3 came with 3.45’s. I swapped out the whole rear axle for one with 4.10’s, you may need more with a 3.0, especially if you have bigger tires. But bang for the buck- low gears!
