- Feb 1, 2026
- Cantonment
- State - Country
- FL - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 3.0 V6
- Total Lift
- 4 inch Lift
- Tire Size
- 33x12.5R15
Hello, I got a 1994 Ford Ranger 3.0 2WD 5-speed manual that I'm pretty serious about converting to 4WD. From what I've heard, it seems to be a pretty daunting task but from what I've seen, It deosnt seem all that diffucult to me (subtle foreshadowing).
I'm swapping the old 3.0 with a 302 from a 1995 Ford Mustang and because I want to keep it manual and cost effictive, I think matting the engine with a M5OD-R2 out of a F-150 will be pretty benfical for my wallet and keep things pretty simple since the shifter location, clutch lines, and overall length is pretty similiar to the one found in the Ranger already, the M50D-R1. So I know I'll need to get a 4x4 M5OD-R2 and I'm pretty sure that a Borg Warner 1356 will mate to the transmission no problemo. However, im not sure how the front end will come together since I would have to replace the TIB with TTB.
I found a 1990s Bronco at the junkyard that has the Borg Warner 1356 as well as all the front supporting components. I have heard some people on here saying that you cant just replace the the beams from the 2WD Ranger with the ones from the 4WD Bronco because of different frame length and all but I'm not very sure about that since it seems as if they would bolt up pretty similiar except for the differing mounting brackets for the beams. I also installed a lift kit on the Ranger so I'm pretty familiar with the mounting points and suspension parts. Additionally, the Bronco has a manual 4x4 shifter so no electronics would need to be run. Lastly, I'm not sure if I will have to cut my current driveshaft or use one from a differnt vehicle.
Thanks for the help!
