Hate to ask again....crown vic help needed once again....
rusty ol ranger
2.9 Mafia-Don
⭐Supporting Member
Michigan
Going on 2 months now trying to get this steaming turd fixed...
A mechanic buddy of mines been pissing with it in his spare time....
Weve replaced intake, maf, fuel pump, filter, and plugs/coils.
99 civilian.
I think we got the original issue figured out...where it was bogging down in the cold.
Now....its got the battery light flickering, a knocking from the bellhousing (im thinking it maybe related....funny i know but youll see why in a minute), idleing high, and it bogs out for a second when put in gear...we also have no refrence voltage at the TPS...
Yesterday i put plugs/coils in it. Fired it up and everything seemed good. I then heard a "pop"...twice...sounded like a starter bendix. After the pops i noticed the engine kinda drop RPM for a minute then come back.
I shut it off and when the engine stopped spinning i heard another....fainter pop. Same noise...just quieter.
Started it again...no problem. As i was sitting there letting it warm up and idle while topping off coolant i heard the knocking noise.....faint at first but getting louder. My first thought was "shit rod" so i shut it off.
Poked around a bit and fired it back up...normal...but knocking. Dropped in in gear noise got much quieter but didnt really have a rythm and definantly coming from bellhousing area. This is when i noticed the battery light faintly flickering....volt gauge was normal. I went to check the battery with my meter and i could get no ground off the battery....or anywhere. I turned on lights, heat, no change. However for some odd reason my lowbeam headlights started working....
Now what im getting at is...could an electrical issue...im guessing a ground....be making the starter do weird shit? Or the starter doing weird shit causing the electric issues?
Anyone know where any of this is grounded?
Could it be a PCM issue?
The vic forums arent much help...i even borrowed my wifes FB and posted in a group....got nothing of value.
So i turn back to my oldest internet friends here.
Bad grounds can cause a ton of different issues. The main grounds off the battery are the first things I replace at suspicion of an electrical problem ever since I had a problem with the Choptop years ago. Doesn’t always fix the problem, but at least I know that isn’t a problem for sure.
I wouldn’t be surprised if they can suffer the same capacitor problems in the ECM as well, might be worth a look.
I managed to dig up a diagram on that charm site.
Theres a wrapped cluster of wires that runs over by the #4 cylinder that i had to manipulate a bit to get that coil pack out...plus however much it got jostled around while the intake got changed...
Looks like the main starter lead from the battery as well as a negative wire from the battery are both wrapped togther in that harness...thats going to be first place i look.
you suspect random starter engagement?
I would definitely check grounds and battery connections. Make sure starter connectiins are tight and can't short to each other.
As far as grounds, Of course there should be a good-sized ground from the starter or really close to the starter back to the battery. Might be another from engine block to body sheet metal, similar the one on Rangers that goes from rear if engine to firewall.
Check alternator connections.
What engine? 4.6l?
not gonna run without a ground....sure as fawk wont crank. might be oxidized on the exterior or your meter probe is shitty or something.
bad ground dont have shit to do with controlling the starter. that is power to the relay side.
the noise could be cracked flexplate or loose torque converter nut wandering around playing plinko...
why did your replace the parts on the list?
One thing we seen on our older 4.6 and 5.4s is corrosion between the engine and trans. It will rust jack the block spacer plate enough that the converter studs will just hit the plate and make a light knocking sound.
We just pull the starter or inspection cover (depending on the year, vehicle, etc) and grind the tips of the studs down a little.
Yes....i know thats strange. But its just a hunch at this point. I know its unlikely compared to say, a busted flywheel but its just very strange it started when the electrical issues started...ill know more in a few days. However it did start fine everytime...so im not sure.
What engine? 4.6l?
I found a list of all the major grounds, one on the pass side fender, one from back of engine to firewall, thebig one that actually does ground down around the starter to the engine, another one that grounds the PCM, and then 3 under the passenger side kick panel. Im will run through all of them. Yes its a 4.6.
Initally i was having an issue with it bogging down in the cold. As he dug into it he found the intake cracked in a few different places....thought it might of been vacuum so we changed that...a few of the plugs were obviously lean as well and went with the cylinders that the cracks went with. Went to pick it up and made it about 4mi before it basically totally quit, brought it back seen it was dropping to like 10psi fuel pressure when you would rev it, that prompted the fuel pump/sock, changed filter too but that was about new already. Plugs were just shot, and some of the coil packs were corroded from coolant intrusion thanks to the manifold. So i replaced all 8 of those...motorcraft plugs and coils.
The MAF i wasnt real sure about but hes a much better mechanic then me and i wasnt going to argue...so we swapped that out.
The engine seems to run frickin great now. Besides the fact it acts like it wants to stall if you put it in gear...which is why if my starter theory is wrong and its not electical causing it im kinda thinking it maybe the torque converter...although the rattle got way quieter in gear...but it also dropped RPM.
Im going to yank the cover on tuesday when i get up there...thats a strange thing but a good thing to check.
for sure some floating power could pop the starter. maybe bad nds. seems it would do that with the key on and messing around with stuff though if its consistently doing it when running.
see alot much more than normal after market starter issues the last few years as well.
if the tips of the converter studs have any contact marks that could be pump walk on the converter and possible pulldown load in gear initially... or there is no feed forward signal through the nds...an issue that may be also bumping starter intermittently or something crazy like that....maybe even a bumping clutch.
or it just needs time to learn the new maf...or the maf calibration is off...
tons of shit. i assume it is a non P I application?
No its not a police model....i believe it is a "performance improved" though...but not sure.
I didnt try dicking with wires with just the key on....thats a good idea.
One thing i thought of this morning...when it was running and driving every now and again if it kicked from OD to 3rd (like, cruise on up a hill) it would make a thud on downshift, i didnt get a chance to look into it much, and it would do it to varying degrees from not hearing it...to holy shit....and if you hammered it it didnt.
Maybe it was the clutch in the converter sticking or something? No idea...just tossing it out. It sounded more like a bad mount. So possibly whatever it was has let loose?
I dont know....ill know more in days coming
I don't know about CV's but '99 was the changeover for the F-150's to go to the PI heads/intake.
I knew the trucks switched then but wasnt sure about the vic
Well i *may* have it licked.
Went out today and climbed in it...was gonna do what bobby suggested, turn key on and wiggle wires...battery was totally dead.
2mo old napa battery.
I also found out my new volt meter is in fact screwed....i tried it on my truck and it wouldnt read...anyways...
I had my mechanic buddy whos house its at ohm stuff with his meter....something was shorted. I started digging into that harness and crawled under and unhooked wires off starter to try and pull the harness up through cause i wasnt finding shit wrong,
Had him reohm it after unhooking starter...he said all was well.
So...i yanked starter (whoever designed this should me kicked swiftly in the nuts...hardest starter i ever did)....took it up to advance to have it tested. It did engage and spin but sounded...odd..but when it said it was testing the armature and whatever else it failed. So it must be some weird starter failure?
My buddy left so i didnt have anyone yp spin motor, but from what i could see from the inspection plate all looked good...but ill look it over real good when i get a starter.
Ok so just to update so yall can share in my misery....
Got the starter changed. Flexplate is indeed fine.
Figured out the rattle was coming from the cats. Both of them. So i ordered cats and installed them last night.
STILL having issues. Its definantly running alot better, the voltage light is still flickering...at idle its barely noticeable but when you rev or accelerate it glows more and more steady. Im going to pull the alternator off and take it to get tested next time i get over there before i dig into wiring.
It fires up and ran great...i drove it 2 or 3 mi out to 127 (main highway) was gonna shoot up and dump gas in it. Traffic was coming so i got after it (probably around 60-70% throttle, just enough it barked the tires a bit) and ran EXCELLENT untill about 45mph...engine lost power, would not accelerate, (did not stall though) if you back off it it would go into a hard missfire. It did this for about a mile or two untill i turned a corner to go back to his house, as soon as i turned the corner and went to accelerate it flatlined, chugged, bucked a few times and took off like a bat out of hell (my foot never changed accelerator postion) and never missed another beat all the way back.
Im really wondering/hoping once i get that battery light situation figured out this goes away, im guessing its throwing the ECM and whatever other sensors into a tizzy with voltages.
Mechanically it seems fine...when its not acting up it runs great.
