Overhead Light Switch Not Working
DeadEye200321
Forum Member
💻 TRS Socials
Arizona
AZ - USA
Vehicle
Drive
4" Super Lift
33"
Back again everyone, I have a 2004 Ford Ranger XLT FX4 and I'm having trouble with my dome light. The dimmer switch for the gage cluster works but when I switch it all the way to the top to turn the dome light on it doesn't turn it on. It used to be an intermittent problem but now I just can't ever get it to work. I know the bulb is still good because the light turns on about 95% of the time when I open my doors and turns off when I close them, but I cannot for the life of me figure out why the switch isn't working. I would imagine the dimmer switch is still working and good because the dimming feature for the gage cluster like I mentioned works but its just the dome light that doesn't work when turned all the way up. If anyone could give me a pointer on where to start that would be fabulous because I'm losing my marbles over it, any help would be appreciated, thanks!
My guess is the switch is bad, it's actually 2 switches in 1, 2 separate circuits.
that and there may be a gem componant downline of that....or special junction box...whatever the hell crazy crap they started doing then
I don't think my truck has a gem module in it, I think that's older ones but I could be wrong.
I'm going to try and replace the dimmer switch and I'll let you guys know if that fixes my issue. Hopefully that's all it is, but if it's not, hopefully someone can help me out.
the special...as in dumb... smart junction box is the modern gem...i use them improperly interchangeably ...
the supervision control is positive...black/light blue pin 14 and the triggers are neg yellow black and gray red....
different then the 2005 posted there...but what my data has for 2004
What the heck is supervision control? Is that what I need to mess with to fix the dome light switch?
that is the main power to turn the damn things on....it can interface with alarm systems and stuff....with entry and dim delay ect... it is delay dimmed ect with timer modules and shit.... cool stuff...but layers of failure i do not need.
Yeah. The GEM later became the "smart Junction Box". Some places or brands call it the body control module.
Ok so it’s not the switch, I went to the junkyard and got a new dimmer switch and took it apart cleaned it up and put it back together so I knew the dimmer switch was good and put it in the truck and still no power to the dome light when I turn it on. What should I try next? Do I need to find a completely new smart junction box to fix the issue or can I take the smart junction box apart and replace the piece I need in there? I’m not super technical about electrical stuff so circuit diagrams and stuff don’t mean a whole lot to me but I can try my best. But where do you guys think I need to check next to fix this?
It depends on what you find. If everything looks clean, you might be able to repair whatever is wrong.
If there is a bunch of corrosion, it might be better to replace the box.
All that being said, have you verified it is something in the box that is the problem? I would hate to replace the box and find out something other than the box was the problem.
Troubleshooting the electrical system is a pain but worth the time investment so you don't throw parts that aren't needed at the problem.
So, is/are the wire(s) that provide the circuit for the light dead at the box? If not, there is something between the box and the switch. What fuse is responsible for supplying power and protecting the circuit? Is it in good shape and now brown residue on the pins? (I had a dead fuel pump for an otherwise good looking fuse that had that residue on the pins).
I just want to make sure you have isolated the problem before you move forward. It is frustrating as all get out but even more so of you throw a part at it and the problem is still there.
There looks like there’s no corrosion in the junction box, how the hell do I even trace the connections for the switch and light? What due would that light be under, looking at the manual to see what fuses are for what circuit. I literally have no idea where to start, where should I start tracing the problem.
You could try picking up a Haynes or Chiltons manual. I know Haynes has wiring diagrams that should give you an idea what is hooked into what. I've only had one Chiltons and that was a long time ago. So, I don't know if they have wiring diagrams or not. I liked the Haynes manual better.
A proper Ford electrical manual would be better, if you can find on. The Haynes diagrams will at least get you going in the right direction. They have helped me a time or two.
I have an electrical manual for my 2011 but there is enough things different about it compared to your 2004, that the information it provides might be wrong for your needs. Plus, they could have changed wire colors over 7 years.
I have Haynes and Chilton manuals for my truck need and some of the pictures are exactly the same. Either somebody was stealing stuff or they're actually the same company. Very little difference.
Ok so good news ish, for some reason I’m not sure why, the overhead light miraculously started working with the new dimmer switch in, but when I initially plugged everything in just to test the switch and see if it was working it wasn’t, but now all of a sudden 2 days in a row it’s working. Why the heck would it be working all of a sudden now? I haven’t messed with the SJB at all yet so would this be a wiring issue or maybe something with everything being mounted up first because it works? I have no clue, will continue to update my findings and if/when it stops working.
