I have a friend with a problem...
Yes, I've personally had firewall flex. It was cracked. Also had the master "ears" that are used to bolt the master to the firewall be cracked/broken. But in those 2 cases I would think you would have problems all the time. But worth a look.
Hey, yall its me the one having the problem. I did bleeding the breaks with the truck running but to my surprise the same result. I have alot of free travel before the breaks even have some what of resistance. Any resistance i have is all the way at the bottom. My thought which may be false is that the master cylinder I got is bad. What yalls thoughts?
1st welcome to TheRangerStation family.
We like to eliminate all the free options before we start throwing parts/money at the problem.
Have you adjusted the rear brake shoes so that they are snugged up to the drum?
Like was pointed out earlier in the thread.
Yes sir. Rebuilt the rears with new springs annd hardware and new wheel cylinders. The drums have not been replaced as I don’t want to dump money into alittle woods truck. My plan is my buddy has a parts truck with a know good master cylinder. Going to put it in and vacuum blead the breaks
1st I don't deserve the sir.
Nor the respect that comes with it.
I'm just a piece of crap floating in the bowl, that most people call life.
2nd if you feel you have depleted all other options and you can get a master cylinder for free and go right ahead and switch it out.
Then as you said once again rebleed the brakes.
I hope this works for you.
Good luck.
Try cracking open a bleeder... with someone else on the pedal... then have them real slowly push the pedal. Note pedal travel before you see fluid flowing. If it starts pushing fluid immediately it means the push rod to master piston is likely good and the master didn't roll a seal cup. Do one front and one rear.
That hydraulic system should bleed without the engine running. Ive never had to run it to bleed all the air out.
Tell me how you adjusted the rear brakes..
Also... we like pictures.
You have a couple pictures of your assembled rear brakes you could share?
Pictures say a lot more then words.
The brake master and booster were both replaced? Verify that the pushrod on the front of the brake booster is set to the correct depth for the master cylinder. I don't recall the exact symptoms, but I've had brakes act funny when I replaced both and it wasn;t set properly. IIRC too long and it's like the brakes are always pressed, too short and it's like you can't press them hard enough.
Here a quick video of how the pedal looks. I will give a look at the rush rod and also snap some pictures of the rear.
Did you adjust the pushrod on the booster to the right length?
Are the bleeders on the top?
There was a guy awhile ago that had his calipers flipped left to right so the bleeders were on the bottom and thus there was perpetually a pocket of air in the caliper he couldn't get out.
I can respond to this one with previous knowledge: YES the calipers are in the right position, but Sean may add something as well and maybe even an image...
Event Coverage
TRS Merch
