Curious Hound
I know a guy with a website
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Feb 7, 2016
- Age
- 61
- Wellford, SC
- State - Country
- SC - USA
- Other
- 2002 F250, 2022 KLR 650
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
So, I've been seriously looking for an Explorer or Mountaineer as a V8 donor for my Ranger. I've been concentrating on 98- 01 models so I get the 5.0l with GTP40 heads and intake for the extra hp - 215 stock. That is 70hp more than my 3.0l was when new. A lot of people on FBMarketplace stink and never reply to potential buyers. So, my search has been difficult within these parameters.
What are your thoughts on the earlier 5.0l engines? If I get an earlier one, what would be involved in upgrading it to the newer heads and intake? Is it as easy as just adding the heads, intake, headers and using the newer ECU?
I'm also briefly toying with doing an LS swap. I see a 2002 5.3l LS with 4l60 and electric transfer case for $1100. But that would require an ecu and digital dash, probably in the neighborhood of an extra $2500. So, while it would be a fun build, it would be more expensive. Here is how it breaks down in my head. Remember, I'm as poor as most of you.
Explorer/Mountaineer swap Pro's;
I get engine, transmission, wiring jarness, ecu, OBDII instrument cluster and more for $1500 or less plus a few "freshen up parts" like water pump, dual sump oil pan, valve cover gaskets, etc. It all fits bevause it's an RBV setup. Easy wiring because it's all in the donor vehicle. Might use complete firewall and dash.
Additional work; engine mounts, new drive shafts, maybe steering shaft work for clearance. I already bought manual transfer case. Just have some fab work to make that fit the truck. Exhaust
Cons; probably more labor the way I plan on doing it. Any other cons?
LS swap ;
Pros; I would go with aftermarket ecu like Holley Terminator or FITech. Great flexibility in tuning. Would not be swapping firewall and complete dash assembly. Good aftermarket support for engine parts. Probably more Hp than the stock Explorer 5.0l. But I haven't looked it up yet. Get to do some cool tech articles for TRS.
Additional work; about the same - drive shafts, exhaust, maybe steering shaft clearance. Some kind of shifter for the 4L60 (probably buy a floor shifter $$)
Cons; cost $$$ - at least twice as much or more. Fitment? I have a lot of unknowns there. Overall length of engine/trans/t-case. Width in the engine bay? Should be able to make it work. And, of course, not Ford anymore.
Tell me your thoughts. Some of the moderators have already chimed in privately.
Edit; i just looked at the tech article again. It's only about a 5Hp dufference between the earlier and later Explorer engines. So, does it really make a difference?
LS swap ;
