My New House & Workshop
I get the need for GFCI, I just think the chances of that being an issue are much lower than anytime I fire up an angle grinder... there's arteries in all sorts of vulnerable areas near where I'm grinding... just as one example
Trying to find 8-foot LED shop lights is becoming a challenge. I want something with 8-foot LED light tubes, and most everything I see has the LED integrated. I don't want an integrated light. I want to be able to replace it if it burns out.
The 8 foot led's that I have seen, I am not impressed. Some of them are made of plastic and they sag. I never have personally messed with them, it might be they come with center supports that whoever did it, did not install.
The 4ft's are more common and cheaper. I actually use the LED 4ft bulbs you can get at Walmart. They work very well and are cheap. I have installed hundreds of the great value Walmart 4ft bulbs, and in the past 10 years I have not had one fail. I had a vendor want to start selling me LED's wholesale, and I told him what I use and the price, and he said he could not match it.
You used to be able to get 8 ft lights that took 4, 4 ft bulbs and dual ballasts. That is the one thing about the Walmart bulbs, they are drop in and do require a ballast.
Now the Great Value LED screw in bulbs, that is a different story. I was buying the 60w equivalent, and I have had a lot of failures with those. So much so I stopped using them and started using the name brand bulbs that Walmart sells. They are GE or Phillips, I can't remember which. I am having better luck with those.
P.S. I am also impressed on how bright the walmart 4ft leds are.
Home Depot has this 8-foot light that takes (4) T8 4-foot LED bulbs:
They have that same light with 4000k bulbs as well.
It's unusual they include the bulbs. I wonder if they use ballasts or direct wired bulbs? I kept going back and forth on it, I wired a whole house with direct wire, but then I started using the drop in that require a ballast. It turned out better for me to use the drop in, since it's quicker for me to install the bulbs 90% of the time, and I can even mix and match regular tubes and LED tubes. But it's whatever you want to go with.
That light from homedepot may just be a empty metal shell with sockets in it if it's using direct wire bulbs.
There it is.
My breakers, GFI breaker, and 40 amp double pole for the tankless water heater.
The water heater threw me for a second because it has a white, black, and green ground connection at the heater, but calls for #8 wire and a 40 amp double pole. So obviously both the black and white go to hot.
The GFI threw me for a second as well because it's so much bigger than a normal breaker. There I had to make sure that the white and black went to the breaker and the white pigtail went to the neutral bar. I cut off the excess pigtail.
There it is.
That thing is so straight and pretty, I would be tempted to use a piece of clear acrylic for the inner cover so I could look at it anytime I wanted to!
Nice work!
Nice work!
Thanks. I'm working on my Electric Subpanel Merit Badge
Nice work!
It needs lights around the edges like a gaming computer though.
I'd rather have the lights in the electrical panel than the computer like that. Especially if they had a battery backup for when I trip the main again. LOL
Is that your rig?
Is that your rig?
Heck no, I just have a laptop. I dont have time for that anymore.
There it is.
Looks great, Jim. Typicalky, that white wire used for the water heater should be marked with colored electrucal tape anywhere it's exposed, such as in the breaker panel, at the water heater and any junction box in between. Historically, that wasn't always done in residential work. But I think modern cilodes and inspectors are pushing it more these days. That tells anyone in the future that that wire is NOT a neutral and in fact has voltage on it.
Great observation. I missed that. Here are the connections at the water heater end.
There's things I still don't understand. Like, why doesn't a 220 have a neutral? (I'll Google it)
I'm using 110 outlet for a window A/C outlet, but apparently I can run the neutral to power and make it 220 and just change the receptacle.
All of my neutrals are attached directly below their breaker, and I pushed the wires to the top of the box before I ran them down to the breaker so there's a little room to drop them down.
Event Coverage
TRS Merch
