My reverse no longer works
Corrin Brannon
Forum Member
Georgia
Last night I drove back home after a successful hunt and parked my 3L ranger with no problems, got in it to go to church today and it would not reverse, sometimes when it’s cold the transmission sticks so I let it warm up and still no luck, tried switching through all the other gears and they work fine so it’s only reverse. Any help would be appreciated hopefully I don’t have to swap the transmission again 🤦‍♂️
(it’s an automatic)
I might have missed something but what year Ranger and which transmission?
Ok... You've done the basics like check fluid level?
If that's good, with that transmission I'd start double checking electrical connections. Edit: especially around the shift position sensor and harness on the side of the trans.
So, usually when the reverse servo o-ring or gasket goes, you lose reverse, then 1st.
Low fluid can cause this too, check it idling in park. Is it red? Does it smell like burnt popcorn? Is there “glitter” in the fluid?
Yes, there are electrical connections on the trans. Make sure they are seated fully and the wires aren’t damaged.
Upcoming TRS Events
Featured Ranger Based Vehicle
