What did YOU do today?
Edited my earlier post for those not aware of my F-150 condition, lol.
So far I've measured for drywall in the shop, I think I need 13 sheets to do what I can in the rooms of my shop, going to try to do that over thanksgiving weekend, looks like 1/2" drywall is around 55lb/sheet so should be able to get it all in the '97 Ranger... of course that takes some work making supports to get over the wheelwells... will make those tomorrow and pick up the drywall Friday, probably won't get that far until next Friday but hey, gotta start and prepare when you can!
I also did some more cleanup and fired the diesel heater for the first time of the season, worked fine, gotta get more fuel tomorrow, almost out.
Is that for lightweight or ultra light sheets? I prefer using those when I can personally. Also, some areas have a 5/8” requirement for garages for more fire resistance, might want to check on that if you haven’t
Honestly don't know, I just googled drywall weight to see if the Ranger would do it easy enough or not :), currently a camper in the F350 that wouldn't care and the other option would be my Harbor Freight trailer but it's from '13 with stock chinese tires...
It's not directly in the shop, I have OSB on the shop side of the walls for abrasion resistance... one room will technically be a bathroom so should probably use the green stuff there... I'll work on a decision tonight. I've never actually done drywall but in my garage where I sheeted the inside with OSB I've definitely done the fitup work...
Drywall isn’t hard, or at least I don’t think so. The only thing I hate is sanding it before paint, so I learned to be good enough to just need a light sand and wipe down with a damp sponge and ready to paint. Some guys are absolute butchers when it comes to taping and finishing. Don’t use the fiberglass mesh tape, that stuff is miserable to get to finish smooth, use the paper tape. If the bathroom doesn’t have a shower or tub, it doesn’t need green/purple/blue board, but it wouldn’t hurt to have it at least around the floor in case there’s ever a leak. That moisture resistant is more for when people steam bath a bathroom wi5 a hot shower or tub soak
I asked and a coworker that lives not to far from me is willing to haul the drywall since he's DD'ing his long bed dually Dodge at the moment so that's easier... :), all said and done he'll probably be out an hours time so not bad...
Got the main room cleared out and the floor swept in all of the cleaned out areas I have right now. This weekend I think I need to get some primer to paint the raw lightly used plywood I put on the ceiling so I can tape and texture it too...
I cleaned up the shop yesterday. Took cardboard recycling off. Found some clear workbench surface area. I should have been doing something else. But ambition was low.
debated driving the ranger to work today, but it was foggy and misty so decided against it. I don't think i drove it at all this week
Yeah, I probably should have been working on a truck yesterday but instead I did some cleaning in and around the shop. I’d like to get a couple things moved so I can get whatever vehicle I’m working on a little closer to the shop because a 50’ cord from the shop barely reaches the front of whatever is parked over there to work on. Little clean-up and moving some stuff and I should be able to get another 10-15’ closer. Probably gonna need to get another load or two of stone though. Plus getting closer gets me away from the corner in the driveway and may give me the ability to put up a carport to work under. Not sure where the money for all of this will come from though, lol
You could always come down and huff paint fumes with me.
Just kidding, I've been wearing a respirator. I have enough issues with skin exposure feom working in fuel tanks. I don't need or want to add issues from breathing in paint fumes.
On the ceiling plywood, doesn’t the plywood expand and contract a little bit with humidity? Maybe caulk it instead of mudding it? I never heard of mudding plywood. Just a thought to consider.
Discovered last night that what my wife really, really wants (as we shop for a new car for her), is a Beetle.
So you know what? She's tolerated me for over almost thirty years, she's getting a friggin Beetle. Guess I'm gonna learn how to work on those lol.
They still make Beetles? I thought they stopped production on the new model a couple years back.
2019 I believe. She doesn't want the 12-19, doesn't like the look. Wants the generation before, likes that it's more "bubbled". Looking at a 2008 with 36k. 2.5 liter (internet says it's the more durable of their engines).
Big thing is I'm going to get good at rebuilding/refinishing interior trim. Apparently European cars of the time us a "soft touch" coating that disintegrates/melts. Gonna be fun. Like most, maintenance keeps it going, neglect and they break. Has some "usual" weak points but nothing too catastrophic.
It's something to learn, so that's good. Most importantly, someone who really deserves to be happy will get something that should do it.
Have had some semi-interesting things at work this week.
First, a recovery mission. Brand new BMW X6 empty body went off-roading and got stuck. That went to the scrap pile. Immediately after that, a fan motor burned up in the AC unit for a production break room and filled the room with smoke. No pix of that. The guys with the big noisy red shiny trucks with flashy lights came for that.
The car bodies ride on skids. This is at a crossbelt where the body should have been moving sideways on two skinny conveyor belts.
Today, i had to move a big heat exchanger coil. Fun. The forklift forks were barely long enough to pick it up. Then, traveling backwards through the plant, I had to detour because the closest roll-up door is out of commission. Finally, after driving a1/2 mile at 2mph so it wouldn’t tip, found out the elevator is broken. So I can’t finish taking the coil up to the penthouse level.
Leaning out the side of the forklift, looking down the side of the 12+ft long crate. The crate wanted to tip forward off the forks.
My view from the driver seat.
Good call, I forgot about that, I was going to get paintable caulk for that... makes way more sense.
