Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
- Aug 2, 2000
- Age
- 58
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
This stupid metal post was concreted in place where my electrical line was going to run, so I had to bust it up and remove it. There was also an old gas line here, some coax cable (no more cable TV for the gophers!), and the old 3/8" copper waterline that I replaced.
I got that all cleared out and ran the conduit under the old gas line.
If you're looking for a workout program to burn calories, might I suggest getting an 8-foot grounding rod and driving it into the ground with an 8-pound sledgehammer. This wasn't too bad until I had about a foot to go, and it decided it didn't want to go anymore. I found myself sitting on a 5-gallon bucket beating the shit out of the thing. My neighbors probably think I'm a nut. For like a brief fraction of a second.... I looked at the section still sticking up out of the ground and thought to myself, if I put a mound of dirt around it.....
Yes, I still have to finish driving it into the ground.
The wheels on the bus go round and round, and the foundation on my shop goes up and down, so I added a slip joint to the conduit. There's one at the house end as well.
I added a pull box at the corner as suggested by @Curious Hound. I tapered the ground down so that I can get more of a straight-line pull when I start pulling cable.
Here's a pic to give you a better fell for where it's going.
I learned something really exciting this week.
There's a
tree stump at the corner of my drive, concrete pad, whatever the hell this thing is. I know the corner was broke up a little and there were dirt and grass on it. I didn't know there was a big ass tree stump here. And unfortunately, this is where my conduit has to go. I already ordered the wire, and I don't have very much to spare, so the tree stump had to get cleared out.
I spent three days with a Sawzall, sledgehammer, and chisel cutting and splitting this stump out of my way. I actually filled up five 5-gallon buckets full of wood chunks from this thing. At times I felt like I was building the million-dollar electrical highway.
It has a nice, neat edge where they framed the concrete to go around the stump. Who does that!!!
Did I mention that I spent three days clearing a path through this thing? There was a huge root about 4 or 5 inches in diameter running under my waterline. So, it's not like I could rip it out with my truck like I would normally do with a stump.
I'm not sure if it was the idiot with the shovel, or the idiot with the sledgehammer, or the idiot that used a pickaxe for a bit, but SOMEONE broke the PVC my PEX waterline is in. Fortunately, the waterline itself wasn't damaged. If you look closely, you can see where the tree was under it. I'm guessing the guy that put this waterline it didn't realize that there was a big ass stump not far from this big ass root.
Yes, I'm the guy. Don't tell anyone.
I cemented the big piece (minus a small piece) back on and then found a piece of drainpipe from my sink, cut it, and cemented it over the broken area.
I'm burying the conduit 20-inches to leave room for the CAT6 conduit that will run above it, so the electrical actually crosses under the water line.
And because nothing is ever easy, I cut out a section of concrete at the edge of the house so the conduit can run up along the side (corner) of the house and get secured to it. The conduit comes in at 45 degrees and then goes into a 90 up.
Here's what I have going on. You can see where the main panel is on the outside of my house, and I pointed to the location where my internet enters the house. This is the area where I want to run the CAT6 cable through. The CAT6 has been more of an afterthought. Since I have the trench dug, I might as well put it in.
I know what you're thinking; if I dig the trench up where I cut out the concrete and ran the waterline, I could save myself 58-feet of line and conduit. That kind of seems like a no brainer now that I'm looking at it. I hadn't really considered my options when I bought 150-feet of CAT6, I just knew I wanted to bury it since I was digging a trench to the shop. Digging the waterline trench back up means I won't have conduit or a cable running between my door and step.
I'm kind of tired of digging ditches though.
There's a
tree stump at the corner of my drive, concrete pad, whatever the hell this thing is. I know the corner was broke up a little and there were dirt and grass on it. I didn't know there was a big ass tree stump here. And unfortunately, this is where my conduit has to go. I already ordered the wire, and I don't have very much to spare, so the tree stump had to get cleared out.I spent three days with a Sawzall, sledgehammer, and chisel cutting and splitting this stump out of my way. I actually filled up five 5-gallon buckets full of wood chunks from this thing. At times I felt like I was building the million-dollar electrical highway.
