I'm running 30-32ish as far as I know. Ill play with PSI and maybe finding some street tires to test on.Just throwing it out there as a possibility, what psi are you running in the tires? A few of us have found that if the psi is to high, these trucks tend to wander some. I'm not sure why, but it does appear to be a thing.
The steering box does have some slop too (330K miles), but I put fresher-ish intermediate shaft in when the old one's slip yoke rusted up.
I would like to try the cheap Jeep shaft swap that I see people doing to eliminate the rag joint on this truck and my 88...but the 88 has a manual box with a smaller spline count.
Generally running with what is on the door jam is good. I did run the math on my 31" load C, BFG KO2s and came up with 36 psi, the door jam says 35. So, unless you are running something out of the norm, the door jam recommendation should be good. It probably wouldn't hurt to do a math check, just to be sure.
High pressure seems to be where the wandering rear it's head. I never noticed a thing with low, unless a tire was real low.
I think makes a pretty even contact patch with whatever is in them now.Over 30psi and mine is a handful. Outside of the tread isn't touching the road either.
A lot of solid axle rigs run steering stabilizers, I wonder of one would help dampen things.
I run 35psi in my crawler on the highway, that actually seems to help with wandering. It gets really sloppy and tippy and weird if I run trail air pressures (10-15psi.) I don't have a sway bar but it's got 73-79 radius arm & coil setup so I wonder if that's just the difference with coils vs leafs.
Bad ass little pit bike, my youngest son has a Coleman CT100U about that size that he's trying really hard to wear out. Mini bikes and scooters and dumb toys like that are so much fun.
I knew the core support and DR middle mounts where shot…but with all the frame work and moving the cab around for the frame repair it broke the rust free that was holding it all together I think lolDang...
That's gotta be the worst set of cab mounts I've seen.
