$6k quote for head gaskets on 4.0 SOHC?
I guess it isn't critical since the motors coming out for head gaskets at the least anyway. Fwiw, I started it before work this morning and it ran great with no ticking.
Maybe it's just the tensioners that use oil pressure to operate are wearing out then.
Chain guides should be making noise whether it's warm or cold.
Yeah it caught me off guard because it's never made that sound. I guess if all goes to plan I should do the whole timing setup on this motor as well this winter. I'm not looking forward to it but what are you going to do?
And new tensioners at least on the donor motor?
I would. We recommend changing them every 70,000 to 100,000 miles, depending on who you talk to. I prefer every 70,000. You also don't have to prefill and pressurize them. Some instructions tell you to do that. It just makes it harder to install them if you do.
Also, check the oil passages that feed the tensioners. Some times they get clogged up. A pipe cleaner will fit in there.
Thanks guys for all your help and suggestions, I really appreciate it. I know I've been all over the place trying to figure this out. Currently having a go with the IRS over the money they owe me for my 2023 tax returns and then my truck starts taking a dump on me 12 days before winter so it had me a bit frazzled lol.
If my truck does have the timing chain rattle will that be fixable when I have the engine out or is that a "scrap the engine" type scenario?
Now I'm contemplating just pulling my own motor and put all of my effort into going right through it. I can grab that other Ranger for $1000 but I could also just put that $1000 into parts and cylinder head work on my motor.
It will be fixable... unless it comes jumps time and beats the hell out of things.
I don't pump up the tensioners when I rrplace them either. I just pull the fuel pump relay and crank the engine to fill the system with oil a few times. The plug the relay in and fire it up.
Awesome thanks. It won't jump time as I don't plan to drive it until it's fixed. If need be my boss said I can take a truck home until I get mine sorted.
