What did YOU do today?
Its not finished, but its mostly assembled. Used the engine hoist to put the hood on. Its rediculously heavy.
So far today I jumped on the tractor to pull that log out, turned out to be 20' long and 3-6" diameter. Then I switched to pulling all the junk out of the boat shed so I could mow in it, then I got on the roof to plug some extra screw holes then vacuumed the leaves out of the boat then backed it in then put all the junk around the boat :)
So after that my day went sideways... my brother had another thing break on the cover crop disc we worked on a couple months ago and his big tractor had giant holes in the bottom of the muffler which melted the dust separator for the intake... So I loaded up a generator in the back of my '90 Ranger and the little Titanium 125 welder and some various scrap metal and such, cut a patch panel out of the top of a 55 gallon drum for the muffler, not perfect but less bad, will get him by a few months anyway. The disc on the other hand the lift linkage nearly fell off. I got it solid enough in the field (only started one small fire... we moved the dry grass and put some dirt on top while I was working...) but it didn't lift high enough so he drug it back to the garage and we hacked that janky link off and found two pieces of 1/2" plate that conveniently had 1" holes already so I welded those together then figured out the angle to cut the other end off to help it lift higher. Now it looks sturdy.
Now it's after 11 and I need to get settled down a bit for some sleep...
I had to swim for help but we're out now. Tried again and got through.
I got all the camping equipment that got wet from the humidity in the West Virginia mountain air out and dried out. I also started stripping the camping gear out of and off of the truck in preparation for winter and putting the fiberglass cap back on the truck. All the roto packs are sitting open on the back porch so they will dry the residual water or fuel out of them. The weather forecast isn't looking promising on that happening soon. No matter, I need to build a shelf or two to store the gear in the shed anyway.
I know my wallet will appreciate it. All that gear hanging out in the air stream was killing my gas mileage. I thought a good chunk of it might have been the mud tires but there was no measurable difference after swapping the mud tires for the all terrains.
Well yesterday I finally got around to putting a pair of TRS stickers (on the bronco), also repaired a little chip in the windshield that showed up around 30k miles.
Had to wash it first.. as I also had some fun in the mud over the weekend..
Ended up buying a 2 year pass to the off-road park 👍🏻 headed back for the third weekend in a row on Saturday.
Armor Ditch? I remember going a couple years back (alone maybe that's the problem) and was not sure paid woods was any better than my normal spots...
