What did YOU do today?
Its not finished, but its mostly assembled. Used the engine hoist to put the hood on. Its rediculously heavy.
So far today I jumped on the tractor to pull that log out, turned out to be 20' long and 3-6" diameter. Then I switched to pulling all the junk out of the boat shed so I could mow in it, then I got on the roof to plug some extra screw holes then vacuumed the leaves out of the boat then backed it in then put all the junk around the boat :)
So after that my day went sideways... my brother had another thing break on the cover crop disc we worked on a couple months ago and his big tractor had giant holes in the bottom of the muffler which melted the dust separator for the intake... So I loaded up a generator in the back of my '90 Ranger and the little Titanium 125 welder and some various scrap metal and such, cut a patch panel out of the top of a 55 gallon drum for the muffler, not perfect but less bad, will get him by a few months anyway. The disc on the other hand the lift linkage nearly fell off. I got it solid enough in the field (only started one small fire... we moved the dry grass and put some dirt on top while I was working...) but it didn't lift high enough so he drug it back to the garage and we hacked that janky link off and found two pieces of 1/2" plate that conveniently had 1" holes already so I welded those together then figured out the angle to cut the other end off to help it lift higher. Now it looks sturdy.
Now it's after 11 and I need to get settled down a bit for some sleep...
I had to swim for help but we're out now. Tried again and got through.
