New members
1994xlt
Forum Member
Morton
IL - USA
Vehicle
Drive
Stock
Stock
good question
Hey all, just bought a Ranger tonight,1998 XLT ranger with a 4.0 and 4x4 here’s a picture, needs a headliner it’s like denigrated or like it’s non existent can’t spell how the word goes my bad, anyways it runs good, brake is soft but I think it just needs adjusted anywho here’s a picture if u wanna ask questions go ahead or give advice and tips those are appreciated I am 17 and have been looking for a truck for a long time now thank you have a good one
Forgot to mention, truck has no brake lights like none at all, signals and running and parking lights work reverse too I think but the brake lights do not at all
Welcome!
If the tail lights work, but none of the brake lights do, I'd verify good bulbs then start at the brake pedal position switch. It's unlikely that all three brake light bulbs would blow at the same time, but weirder things have happened, and it's possible that the PO (previous owner) just didn't bother checking and all three burned out over time.
Okay thank you, it did sit on a barn for 3 years before I bought it is there anything else I should check?
Welcome to TRS.
Congratulations on your purchase. Is this your first vehicle? Regardless, you're gonna love it. Back seat area is a little cramped, but you don't have to ride there :p
Good advice from Josh. Taillights are getting juice, just not getting a signal to turn on.
From the image you posted the truck looks pretty clean. Post up some more when you get the chance.
EDIT:
If you're asking about "other" things beside the taillights, yes there are other typical things, like fluids for sure if it's been sitting for awhile. Fuel for sure cuz it gets old and skanky which could lead to other problems. Go easy on it till you get it all sorted out.
welcome!!!
for your soft brake pedal, try bleeding the fluid and see if it improves. if not, you might have some rubber lines that need to be replaced because they are expanding when you push the pedal ( like a balloon ). hopefully just bleeding the brakes fixes it for you though.
and i would check the brake light switch at the brake pedal. see if its out of adjustment, or maybe bad. you can pull it off and check it with a multimeter and if it reads good, reset it so the brake pedal arm pushes the switch pedal fully and then hopefully your brake lights come on
Welcome to TRS.
EDIT:
Supposedly this truck came from Texas, since it sat the old owner drained the tank out and changed the fuel filter, do I run a tank or 2 of gas thru it and change it again or don’t worry about it?
welcome!!!
Ok thank you my dad said he was just going to order a new one but I might just test it. He works at a ford dealership so he has access to specific tools and lifts and stuff so that makes it easier for me I giess
If you trust what he said, no. Just put 1/4 tank and run. Knowing you pop has access is way cool...extreme advantage.👍
Ok, thanks, do you know of any known aftermarket headliner kits the one I have the headliner pretty much gone, also the radio is aftermarket and every time I hit a bump the sound goes away also you can’t turn it up very loud otherwise it sounds like garbage so dos anybody make a speaker and radio kit?
Post up some images of your radio and the headliner. Stating the obvious here, but most everything is available online, but that stuff costs.
There are audio experts here and there are lots of different things you can use for the headliner. It just depends on your budget and how bad the damage is - and your skill level too.
There are sales brochures HERE...that you can browse thru that will show you what you should have as well as lots of other basic info. the Tech Library is also a great resource. (y)
Thanks for the sales brochure also haven’t drove it to test it but my radio i literally just touched the darn thing and it fell out so I put it back in and for the 5 mins I messed with it the audio didn’t cut out
Im sorry I totally just realized I said I had a 98 I have a 94 ranger sorry I will go look for the brochure now for a 94
That makes it easier for me cuz I have a 94 as well. It's a Splash SuperCab, but similar to XLT trim. Couple of other 94 owners here as well that are pretty active. Doesn't matter though, lots of helpful peeps here. Later...
Welcome! Good first post.
The 1994's are good trucks. My favorite year.
Do post up pics of your headliner and radio. If the headliner backing (it's pressed and molded fiberglass) is still good, recovering the fabric is a good DIY project. On the radio, it sounds like you're fixing to learn how to rewire a hack job. It's not hard; even a cave man can do it.
Brake lights- get a 12 volt test light; very handy to have anyway. First thing I'd do is to check for power at the brake light switch, on the brake pedal. If power is not there, look upstream and check the fuse next. If power is there, then look downstream at the bulbs, and also look at the wiring harness behind the bumper to see if it's been hacked into in the past for a trailer harness.
Good; between that, and finding this place, you got it made in the shade! :cool:
Event Coverage
TRS Merch
