Help with RTV location re gasketing engine.
BigBlue94
Greenville
NC - USA
Vehicle
Drive
1994 Ranger 4.0L
Hello everyone, I recently got my hands on a clean set of valve covers and need to give the top end of the motor some TLC. I will be replacing the valve cover gaskets, manifold plenum gaskets, upper and lower intake manifold gaskets. I am having trouble understanding where I need to place RTV on the valve cover gaskets and the lower intake manifold gasket. I uploaded a photo of the valve covers and a photo of the lower intake manifold area. I have a one piece gasket as well.
For the lower intake manifold gasket, from my understanding RTV needs to be placed on the china walls and the rear/front portion of the gasket where the small rectangles are. And nowhere else?
If anyone could lend a hand and dumb it down as much as you can, it would be greatly appreciated. Thank you for your help.
I think with the one piece gaskets you just need a little dab where the heads and block meet
I also like to put gasket shellac on the valve cover gaskets to try and make sure they don’t leak.
I used a one piece gasket on my first engine and had to cover everything between the heads at the front and back of the block. There was like a 1/4 in. gap. It was silly.
I put it together by the directions I had the first time and had to redo it. Fired up and there was oil splashing out the front.
When I did mine, I ordered a FelPro gasket set from Rock Auto. It came with a two piece gasket that replaced the one piece original. The RTV was placed at the front and rear "china walls" as you call them (not heard that reference before), and a couple other spots. This is what I have, hope it helps some.
Hi BigBlue94 ,
I am doing similar work on my 94 Ranger, however, the mounting holes on my valve covers are rusted out and would be a leak source.
So, i am looking for valve covers like the ones you were able to find.
Can you direct me to a site where i could order a newer set?
Thank you Sir!
Junkyard is probably it...
I see right sides on e-bay. Can't find a left though which is weird cause it should be more common...
Hi BigBlue94 ,
Thank you Sir!
Depending on how badly rusted they are, you could try to repair them. Depends on your skillset, time and money.
I'm cheap.
Next is, as SenorNoob suggests, the pull yard.
An finally, internet search. They are out there:
Valve Covers
Thanks!,
i saw the right side as well on ebay, but not both.
I'm cheap.
Valve Covers
Thanks, they are in pretty rough shape at the mounting hole areas.
I will keep searching!
Thanks!
Event Coverage
TRS Merch
