Help with RTV location re gasketing engine.
BigBlue94
Greenville
NC - USA
Vehicle
Drive
1994 Ranger 4.0L
Hello everyone, I recently got my hands on a clean set of valve covers and need to give the top end of the motor some TLC. I will be replacing the valve cover gaskets, manifold plenum gaskets, upper and lower intake manifold gaskets. I am having trouble understanding where I need to place RTV on the valve cover gaskets and the lower intake manifold gasket. I uploaded a photo of the valve covers and a photo of the lower intake manifold area. I have a one piece gasket as well.
For the lower intake manifold gasket, from my understanding RTV needs to be placed on the china walls and the rear/front portion of the gasket where the small rectangles are. And nowhere else?
If anyone could lend a hand and dumb it down as much as you can, it would be greatly appreciated. Thank you for your help.
I think with the one piece gaskets you just need a little dab where the heads and block meet
I also like to put gasket shellac on the valve cover gaskets to try and make sure they don’t leak.
I used a one piece gasket on my first engine and had to cover everything between the heads at the front and back of the block. There was like a 1/4 in. gap. It was silly.
I put it together by the directions I had the first time and had to redo it. Fired up and there was oil splashing out the front.
When I did mine, I ordered a FelPro gasket set from Rock Auto. It came with a two piece gasket that replaced the one piece original. The RTV was placed at the front and rear "china walls" as you call them (not heard that reference before), and a couple other spots. This is what I have, hope it helps some.
