D60 and 14b build
Cage arms finally came in! These things are fricken' huge. They came in at 65lb each with rod ends and fasteners. Some pics...
D60 and 14b build
D60 and 14b build
Can't wait to get them on! :icon_welder:
Well, I went back out to the farm last weekend and got basically nothing done. :huh: I bought some F250 shock mounts and some 5.5" w/ winch EB springs from BC Bronco's. Just a matter of finding time now.
The 14 bolt and skyjacker leafs are in also, but no pics.
lookin good Brendan, i see you went with the cage rad arms, you weren't jokin, those things are fuckin sick!
they look just like my james duff one same joint and all
That's because they are designed by the same person. The designer left Duff and went to Cage.
Pulled the transmission this weekend. It died a few months ago just before I pulled the diffs for the swap. Turns out that the output shaft from the trans to the t-case broke. Looks like a pretty normal break, but I thought the stress cracks were kinda unique because I've never seen them before.
D60 and 14b build
D60 and 14b build
Here's some more of getting the 60 mocked up and set at ride height so I can figure out where to mount the radius arms on the frame. I also spaced the coils out a bit temporarily with a 2x4, just for mock-up. I'll build a spacer to go in there later.
D60 and 14b build
D60 and 14b build
Whats your height gonna sit at from spindle center to wheel well? Mine's gonna end up around 27", running 35's first and eventually 37's.
-andrew
just something to think about if you are running 38s on a 14 bolt you are going to be draging it everywhere because the diff is so big i would go to 40s or shave the rear alittle
-andrew
I don't really know, I've never measured it. I'll have to check next time I go to the farm.
As for the 14 bolt, I don't think I'm going to shave it just yet. It's only a few inches larger than the old 8.8, and for what I'll be doing with the truck, it's not that big of a deal. Not to mention, I've already got huge gains by swapping out that mud/snow plow that we know as a ttb.
I just got a dana 60 and a 14 bolt and doing what you did. my problem is the dana 60 is a GM with a passenger drop . the other guys are saying i can still use it .....only i have to drill the plug welds and swap the tubes. is it true that the inner c's are the same and won't be a problem. did you shorten you 14 bolt at all or just threw it in there wide? what else do i need to know about this swap?
Pics of the trac bar and other goodies:
D60 and 14b build
D60 and 14b build
The top rod end goes to the engine crossmember, and the bottom is for the trac bar. I used the steering box bolts, the bolts from the engine damper, and I'll also be putting a couple of beads on each side to help distribute the load. It also still needs to be removed, cleaned up, and painted.
D60 and 14b build
