I'm sure I got a short.
@alwaysFlOoReD I checked the transmission fluid level on Thursday when it was like it was slipping a little bit.
The fluid level was right at the hash mark section of the dipstick where it says don't add no more.
@alwaysFlOoReD yes today is Monday.
not in my world....its still yesterday....tomorrows yesterday will be monday tomorrow, some people will call that tomorrows yesterday could be tuesday but its just like any other day....
like today.
@bobbywalter I believe what @alwaysFlOoReD is saying is, it's a new day warm the truck up and check the levels again.
Which I will check the levels again tomorrow. I'm not doing nothing today.
Well I was able to do some more checking on my truck today.
I now think the transmission fluid level is to high.
And I'm sure it is slipping.
And on top of that I've now found an antifreeze, radiator water leak.
It appears to be coming out of the top middle bolt hole of the passenger side exhaust manifold.
Does this mean I blow the head gasket?
Or do I just need to tighten that bolt some more?
I made a video but I can't figure out how to make it into a link on my new phone.
That's already broken. I broke the screen the other day.
Can anyone tell if that link to my video works?
Thanks.
It didn't work so I deleted it.
I can see a 20sec video...
Thanks @Brain75 & @alwaysFlOoReD . for letting me know that link works.
The bubbles you see in the video seems to be water/antifreeze,
that appears to be coming out of my top middle exhaust manifold bolt hole, between the head and the exhaust manifold.
Once again I'm fed up with my truck.
I'm now sure I have the transmission fluid level to full by just a little bit.
The transmission is for sure slipping.
If I stop the truck on a hill I have to use the accelerator as if my truck was a stick shift instead of an automatic, To keep it from rolling backwards or forwards depending on which direction the hill is.
And on top of that I have a transmission fluid leak somewhere.
P.S. to my last post.
I'm also out of data on my phone so I have to go over to 1 of my brothers houses to use their wi-fi to get onto the internet.
So please bear with me about how long it takes me to reply to everyone's posts.
Thank you to everyone who tries to help me.
Even if it's so small as just encouraging me to not give up.
Your Ranger is relatively simple. You got this!
