- Apr 13, 2009
- '06, '11
- 3.0 V6
FYI, not for steel, but for aluminum, use wd-40 or equivelant.
So… I will say that o do really like Tap Magic for cutting threads… I just use regular oil for drilling though. I had some spray cans of some drilling stuff but apparently they are gone now because I can’t find any. Tap Magic gets pricy for drilling fluid.
I’ll also say that, @Blmpkn , check what speed it runs at. My benchtop HF drill press, the slowest speed is still waaayyy too fast for steel. It will drill, but it’s too fast. I’m considering ways to resolve that…
So for twist drill bits:Any idea what the optimal RPM is for cutting steel? With a hole saw? Idk if it makes a difference hole saw/drill bit but I imagine it does..
Either way, it's actually pretty slow when it's set to its slowest speed.. like... mabey right around what an old 12v cordless drill would do wide open.. perhaps even a little slower. All I know is it's way slower than an 18v drill lol.
I'll have to see how fast the motor says it spins and then measure the pulleys and do some maths tomorrow.
1/16-3/16” bits - 3,000
1/4-3/8” bits - 1,000
7/16-5/8” - 600
11/16-1” - 350
Countersinks I saw anywhere from 50-560 rpm and there seemed to be a bit of disagreement over where it needed to be. I haven’t gotten around to pulling out my machinists books to see what they have to say.
Bimetal Hole Saw Speed and Feed Table (RPM Chart)
Bimetal Hole Saw Speed and Feed Table (RPM Chart)drillsandcutters.com
You’re welcome.
This is super awesome, thank you.
Looks like a 2.5" hole saw wants a measely 130rpm for mild steel.
I'm betting my press is like yours then.. probably way too fast even running its slowest setting..
I'll have to get to math'n tomorrow.
The way I've heard to get the best cutting and life from the bit is to figure out the feet per minute at the cutting edge, then adjust your rpm to that. I don't have that info but I'm sure if you goggle it that there will be charts for all the different metals and types of bits.Any idea what the optimal RPM is for cutting steel? With a hole saw? Idk if it makes a difference hole saw/drill bit but I imagine it does..
Looks like the alternator bracket is to the frame? So the engine is solid mounted? And the water pump is run off 12V electric?Productive day here - All that's left now is headers, plugs and wires, carb, radiator, grille and hood. Had to fight with the alternator bracket to get the belt aligned properly but we finally figured it out. NHRA Canadian Open starts Thursday so it looks like we'll be ready for it.
